Looking for a Digital Coaxial cable bewtwwen CDP ---> DAC (MIT AVT line?)
acmf74
acmf74 Posts: 937
Hi,
I'm looking for a new coaxial digital cable and my budget is around $100.
Has anyone have any experience with the MIT AVT line? I'm also open to suggestions.
Thanks,
Post edited by acmf74 on
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited August 2013
    What length do you need?
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
    tonyb Posts: 33,065
    edited August 2013
    What do you have now ?
    Lots of guys use the Blackcat Veloce.
  • acmf74
    acmf74 Posts: 937
    edited August 2013
    I need a cable between 1.5M - 2M in length.
    I currently don't have a cable and looking for suggestions.
    Thanks,
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited August 2013
    http://www.accessories4less.com/make-a-store/item/IXOSXHD608200/IXOS-Xhd608-Digital-Coax-Audio-Cable-Silver-Plated-2m-6.5ft/1.html
    Won 'digital audio cable of the year award' in What Hi Fi Sound and Vision 2 years in a row.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • Speedskater
    Speedskater Posts: 495
    edited August 2013
    At 1 or 2 meters, any cable of MonoPrice quality or up will work. Once you get past about ten meters then cable quality starts to get more serious.
    EndersShadow Posts: 17,687
    edited August 2013
    tonyb wrote: »
    LOVING mine!
    Thanks again Phil!
    tonyb Posts: 33,065
    edited August 2013
    LOVING mine!
    Thanks again Phil!
    LOL....you fanboy you. Glad your diggin' it. Phil gave you a helluva price on that puppy to. You best buy the guy a beer or 10 if you ever run into him.
  • pearsall001
    pearsall001 Posts: 5,227
    edited August 2013
    LOVING mine!
    Thanks again Phil!
    You're quite welcome...that is one hell of a cable!
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2013
    I purchased the AES version of this for around $100. I'm not sure if it was a mistake or not, but there were two in the package. It sounds pretty good on my spare system. Once I get some time on it I will compare it to my $750 Zytron Python digital.
    http://bryston.com/products/other/digital_RCA.html
    edited August 2013
    tonyb wrote: »
    It's not being a fanboy if it just sounds stinking GOOD!
    And it does. Opened up my soundstage.
  • 11tsteve
    11tsteve Posts: 1,166
    edited August 2013
    i have one from this fella, and I like what it did over my cheap TOSLINK cable. and seems to be very well made.
    http://www.groverhuffman.com/interconnects
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
    tonyb Posts: 33,065
    edited August 2013
    Not a bad price either ^^^. Plus he has the length you require, the Blackcat only comes in one length.
  • 11tsteve
    edited August 2013
    just a word of.. well, knowledge. Grover is a bit on his own schedule. It might take a little longer than what is normal to get your cable. IIRC, it was something like 3 weeks+ between ordering and my doorstep.
    I choose him based on another member's review of both the digital cable and IC's. At the time I was using a Tributaries TOSLINK, and just was experimenting with finding out of a digital cable would matter.
    To my ears, the stage opened up, I lost some edginess in the vocals, and everything just seemed a bit more anchored. And quieter... meaning I think I had some sort of noise from the TOSLINK. It may sound weird, but I can't tell you what it was, just that I noticed it was gone.
    I would like to try a set of IC's from him, but there is a pair of Infinity RSb's in need of inductors first.
    Polk Lsi9
    Keces DA-131 mk.II
