Yaquin cd-1 tube buffer question
laotzu61
laotzu61 Posts: 327
edited August 2013 in Electronics
is this puppy as good as it proclaims to be as far as providing "tube-like" sound. I would be interested
in putting one between the pre and power amp. thanks.
"The symbol is not the reality"
Post edited by laotzu61 on
  • 98Badger
    98Badger Posts: 317
    edited August 2013
    Short answer....No. I owned one for a short time. It was not a good fit for my system. Smoothed out the highs, but muddied up the mids and bass in my system. I later had a Rogue Audio preamp that gave me a much better feel for what tubes are about.
  • trav0810
    trav0810 Posts: 1,056
    edited August 2013
    I have a yaqin CD-3. I did not care for it between my amp and my pre, but I really like it between my CDP and my pre. I liked it enough in that capacity that I kept it over the Bada tube CD player I bought.
    The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
    Sony Playstation 3 for CD and Streaming
    Thorens TD320
    Modified Carver C-1
    Carver TFM 42 and 45 Amplifiers
    Polk RTA15TL Speakers w/Decato mods
    White Lightning Moonshine DIY Speaker Cables and Interconnects
  • zingo
    zingo Posts: 11,258
    edited August 2013
    It will not make your non-tubes sound like tubes, but it can improve the sound if you have an impedance mismatches between equipment.
    pitdogg2 Posts: 27,187
    edited August 2013
    laotzu61 wrote: »
    I have a CD2 works good between my amp and pre. I recommend some of these THEY ARE TO DIE FOR!!!
    http://www.ebay.com/itm/310717276975?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    bought some from this very seller super fast shipping and very good tubes. you can get the same tubes from USA seller for 40.00. I liked the 14.00 so much I bought 6 pair all matched.
    So far i have used JAN GE,Siemans and Tung-Sol. The Russian tubes have it all great bass wonderful mid range and crystal clear highs.
  • laotzu61
    laotzu61 Posts: 327
    edited August 2013
    trav0810 wrote: »
    I have a parasound hca-1200 amp and hafler dh-110 pre. I don't think I have an impedence match problem. they're connected
    to rta12b's. and thanks for all the input.
  • laotzu61
    laotzu61 Posts: 327
    edited August 2013
    zingo wrote: »
    oops. wrong quote in my last post. should have been this one. the parasound is 4 ohm rated, which is what I need for the rta12b's,
    which are 4 ohm speakers.
