New TV...connection problems
michael1947
So my daughter finally (thank you god) moved out and with her went her 46 sony tv and sony blue ray. I replaced the tv with a Panasonic TC p50S60 plasma which has a very fine picture even though it is at the bottom of the Viera series. I pulled a Visio blue ray from my basement rig to get working. I don't watch "real tv" on this rig very often.
I watch a movie a night...maybe 4 a week and after the movie I like to go to u-tube for some music as I like the visual along with the audio. On my old set-up I used the Sony blue ray for the u-tube after the movie but the Visio will not go to u-tube and the Viera does very well with u-tube. Problem with the set-up is hook-up. The only outlet left on the Panasonic is an optical. I hooked a short one up for a test and it sounds fine but was wondering if there is a better way to keep the HDAMI signal traveling back to my Onkyo TX-NR 708
I have an ATT Uverse system that feeds directly into the tv with HDMI and I have it hard wired from the modem for the internet. The tv has only 2 HDMI in's and the other is used for my blue-ray.
I have ordered a 6 foot toss-link cable to finish up the installation but am wondering if there is some benefit to working up a HDMI splitter from the tv to get the HDMI audio back into my Onkyo. Will the fiber optic carry signal as well as HDMI? Do I pick up a u-tube compatible blue ray player?
Also is there another option with my Onkyo? I have it hard wired to the modem but I have never used it to my knowledge. Is it possible for the Onkyo to pick up my u-tube, Netflicks, Amazon and the other usual suspects and have it displayed on the Panasonic via the existing HDMI connection?
Sorry for the long story but I know the more info you have the better you can analyze the situation.
Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
Post edited by michael1947 on
Those optical cables are for audio...when equipment is setup for bitstream I find they do very well
Yes, I understand and in my test the audio did perform satisfactory with the audio out via optical into my sound system. Just wondering if I was missing anything by not following the HDMI circuit all the way to the receiver. Thanks.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
Run your source to the reciever and use your tv as a monitor....set it up as V1 for your tv program...V2 for yer blu ray...just switch em for what you want to see using the remote for the reciever ....should work fine
What he said here. Bitstream via optical should sound pretty good. Someone can correct me if I'm wrong here, but I think all you're missing not using HDMI vs optical is optical doesn't have the ability to decode DTS-HD MA and Dolby TrueHD. I don't stream, so does Netflix or YouTube even send out those signals? If not, don't think you're missing much using optical. Maybe someone more into streaming can chime in on the signal... -
Thanks a lot fellas especially using the receiver for the switching. I knew there was another way, not that I'm terribly opposed to the fiber optic and will install it upon it's arrival. In the meantime I will re-route the HDMI. :razz:Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Optical will work as long as there is a DTS decoder in the reciever....5.1 will work too if the source material is not DTS encoded...BluRay will do either....streaming would depend on the source material.
