So what is your favorite speaker cables to date?
2
  • headrott
    headrott Posts: 5,496
    edited August 2013
    GFOviedo wrote: »
    I didn't say anything about saving anyone money. I was simply stating my opinion.
    Ok, so as F1nut (Jesse) brought up, what cables have you tried to base this opinion upon? That is what this thread is about; finding peoples' opinions about what they consider the best speaker cable and best "bang for buck" speaker cable they have tried. What speaker cables have you tried and what speaker cables do you consider best and best B4B?
  • GFOviedo
    GFOviedo Posts: 353
    edited August 2013
    I've only tried 4 brands. All of them were 12 gauge. Bluejeans, Monsters, Audioquest, and what I currently use monoprice 12 gauge CL2, which I cover with black sleeve, use speaker wire pants, and Swelle deadbolt banana plugs.
    Don't ask me the model of the cables since they were borrowed, and given back after completing my speaker wire runs with Monoprice. However, I can say I didn't noticed any difference in sound.
    AVR: DENON X4000
    FRONT L/R: ARX A3RX-C
    CENTER: ARX A2RX-C
    SURROUND L/R: ARX A3
    SUBWOOFER: PSA-XV15
    SERVER: UNRAID 15TB
    MEDIA PLAYERS: DUNE SMART SERIES D1
    HDTV: VIZIO M601D-A3R
    EndersShadow Posts: 17,705
    edited August 2013
    Makes sense to me I used 10ga for the longest time 12ga is so yesterday........
    I use 12 coat hangers strung inside a garden hose for insulation :razz:....
    Just kidding...
    But in all honestly I like my Audioquest FLX 14/4 speaker wire for budget stuff. Its good for bi-wire, bi-amp, or just really large gauge single runs. All from the same cable and its about as cheap as Monoprices speaker wire.
    But I LOVE my Kimber Kable 8VS speaker wire. Not as expensive as the MIT stuff, but more costly than Blue Jeans and Signal.
    Just got in some of Doug's 9 AWG speaker cables and interconnects and will be playing with those for a bit so will check back and see if things change :biggrin:
    pitdogg2 Posts: 27,065
    edited August 2013
    I use 12 coat hangers strung inside a garden hose for insulation I used Tool Dip worked as well as anything Coconut Audio sells at 1/2 the price
    Just kidding...it works better than Coconut Audio at 3x the price
    Fixed it fer ya
    edited August 2013
    Fixed it fer ya
    You forgot its sprinkled with pixie dust, and has pieces of unicorn horn pieces embedded in it. That paired with the flawless diamonds hand picked by a blind man in China, tuned by strumming the wire on his guitar. It doesnt get any better till you buy the cables made by the Skidders....
  • ratster
    ratster Posts: 324
    edited August 2013
    So far the best has been from Signal Cable. However,the mailman just dropped off a pkg.from Clear Day consisting of new shotguns and jumpers. We shall see......
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Clear Day dbl.shotgun
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
    Clear day dbl shotgun
    edited August 2013
    Well I didn't want to let all your secret's from corporate espionage out...double ought cypher naught.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited August 2013
    As most people around here know I use 14 gu clear primarily out of financial constraint and then not just being well informed. Forget for a second what all your opinions are, I called multiple companies w/ the science rap why their cables are the go to pairs.Lower the gu. and of course it lowers the resistance that's I think is Ohm's Law or part there of and then the whole OFC deal and then quality terminations. Boys I I'm learning and like we used to say I will UPGRADE to the front row some day.
    nooshinjohn Posts: 25,931
    edited August 2013
    GFOviedo wrote: »
    looking at the gear in your sig, I would say that your cable choices are commensurate with your needs. I am in no way trying to bash your choices, it's just my opinion.
  • acmf74
    acmf74 Posts: 937
    edited August 2013
    Mono 12ga ---> Audioquest Type 4 ---> Signal Cable Ultra ----> MIT CVT-2/MIT (T2) HT2S (center channel)
    I slowly went up the chain in speaker cables and found subtle improvements but the MITs hands down were the best BY FAR in all categories.
    When I went to the MIT center channel I was blown away in the SQ. It really sounds like a different (better speaker)!
    tonyb Posts: 33,072
    edited August 2013
    DSkip wrote: »
    Agreed. This is a hard point to make without offending someone, but you represent the general population of "cable is cable". Their virtues and downfalls become readily apparent as you step up your game.
    Bingo.
    No cable will make an entry level system sound like it cost 3 g's more. That's why we always say as your system improves, so should the cabling. Just common sense really.
  • GFOviedo
    GFOviedo Posts: 353
    edited August 2013
    Here a thread from the AVSForum where I learn how to do my "dress" my own 12 gauge cables. If anyone is interested:
    http://www.avsforum.com/t/1301573/have-a-look-at-these-beauties-how-to-make-your-own-high-end-cables
    AVR: DENON X4000
    CENTER: ARX A2RX-C
    SUBWOOFER: PSA-XV15
    SERVER: UNRAID 15TB
  • BlueFox
    BlueFox Posts: 15,251
    edited August 2013
    It makes "The Stupid People" feel better.
  • Jhayman
    Jhayman Posts: 1,548
    edited August 2013
    I once thought as you did young Padawan, BUT since I have actually tried different one's I can Honestly tell you there IS a Difference..
    All depends on your budget..
    GFOviedo wrote: »
    Speaker wire is speaker wire, it doesn't matter how you pretty they are. I can't believe how much money people spend on these! Then again, if you have the money that's cool :cheesygrin:
    edited August 2013
    Jhayman wrote: »
    True enough it took us awhile to brainwash him into believing, but it was worth the effort....wasn't it?
    edited August 2013
    WTF??
    Why is pepster listed as a "guest" now under his username????
    Did I miss something?
    F1nut Posts: 51,790
    edited August 2013
    GFOviedo wrote: »
    I'm not.
    F1nut Posts: 51,790
    edited August 2013
    WTF??
    That would mean he asked for his membership to be terminated.
  • Boonaroo
    Boonaroo Posts: 57
    edited August 2013
    About 3 years go I picked up a pair of Nordost Vallhalla's at an estate sale. They had no idea what they were, even though they had some high end equipment priced accordingly. Paid $25 for a set of $5000 cables. My best pick to date.
    They were excellent cables, but I sold them on A-gon and purchased my motorcycle.
  • kevhed72
    kevhed72 Posts: 5,146
    edited August 2013
    Right now....used AudioQuest CV-6s.
    I also liked the MIT T4s I used to have in my RTiA9s.
  • steveinaz
    steveinaz Posts: 19,545
    edited August 2013
    Kimber 8TC, for over 9 years. No desire to replace.
  • SHOKDU
    SHOKDU Posts: 47
    edited August 2013
    The absolute best speaker cable that I have ever used were completely custom built to my specifications. The cable detail;
    A #4 solid, oxygen free conductor, gold plated and then covered with a kapton coating for the first layer of insulation. The second layer of insulation was a high dielectric, low swell, EPDM rubber - this was primary insulation. The third layer of insulation was a high modulus, EPDM breathable rubber. Lastly, the cable was then covered in a bedding jacket to prevent mechanical damage. The connector ends were formed into a spade configuration from the same solid conductor, and also gold plated. The cables were rated for usage up to 400*F, and were pressure tested to 1500 PSI for an extended duration. During the pressure test period the wires were also burned in at 3289 volts, but the cables were rated for 5,000 volts. The wires were meticulously made for my system, and as its a solid conductor it is quite stiff. The wires must be pre-bent at the factory to exact measurements.
    Unfortunately, I sold the speakers that these wires were manufactured for, and as everything was prebent to spec, the wires went with the speakers. The price was ungodly high for these cables, and I don't think I even want to share that information.
  • kevhed72
    edited August 2013
    Dude, those sound awesome....do you have any pics?
  • BlueFox
    edited August 2013
    kevhed72 wrote: »
    Yes, and why those specifications?
    heiney9 Posts: 25,445
    edited August 2013
    SHOKDU wrote: »
    That much attention to detail on cables and no detail spent buying Emotiva. Something doesn't quite add up here. For now I'm taking your cable post as tongue in cheek. Convince me otherwise. Pressure testing and heat testing aren't relevant for in home audio cables. Explain the significance in a home audio arena.
  • SHOKDU
    SHOKDU Posts: 47
    edited August 2013
    H9, if you paid attention at all to my previous posts in the bickering threads, you'd have read that I have had much more prestigious gear in my past, and that due to life changes I was forced to part with it all. At that point is when I settled for what was attainable, which happened to be Emotiva. That is when I started getting into vintage hi-fi as well, as it is much cheaper than what I had been accustomed to.
    For the rest of you, I am working on a reply with some details of why certain components were used, and the relevance to not just home audio, but cables and electrical conductivity as a whole.
  • SDA1C
    SDA1C Posts: 2,072
    edited August 2013
    The most favorite wires I have ever used is .052 copper coated welding wire insulated individually by continuous heat shrink then twisted in pairs for 25 ft runs. Shrunk in the powder coat oven for about 15 minutes then sealed again with an outer layer of 1/4 inch vacuum line. We hard soldered gold plated ring terminals and clipped the end to make them spade connectors. The speakers involved were a dual ten inch Altec model ? with the sticky paper cones. We used a Vector research 35 watt receiver that weighed a metric ton. I swear we could pick up Siberia with that thing.
    Anyway. I kid you not. These wires were the most amazing and unexpected upgrade to any stereo system I have owned to date. I have not tried them again on any other rig and no longer have them but since this jog in memory I may assemble another pair.
    Too much **** to list....
    F1nut Posts: 51,790
    edited August 2013
    Post by shokdu on Jan 5, 2013 at 11:37am
    All of my cables come from Monoprice, and that will never change...
  • SHOKDU
    SHOKDU Posts: 47
    edited August 2013
    SHOKDU wrote: »
    H9, if you paid attention at all to my previous posts in the bickering threads, you'd have read that I have had much more prestigious gear in my past, and that due to life changes I was forced to part with it all. At that point is when I settled for what was attainable, which happened to be Emotiva. That is when I started getting into vintage hi-fi as well, as it is much cheaper than what I had been accustomed to. .
    Put it together, Sherlock. Your Google-Fu is incredible, but your logic is not.
    My future purchases wont ever change, due to my life circumstances.
    F1nut Posts: 51,790
    edited August 2013
    Kapton seems like a poor choice, granted a different application, but still....
    It was found to have very poor resistance to mechanical wear, mainly abrasion within cable harnesses due to aircraft movement. Many aircraft models have had to undergo extensive rewiring modifications, sometimes completely replacing all the Kapton-insulated wiring, because of short circuits caused by the faulty insulation.
    Interestingly, Kapton is also used with an aluminum backing for the ribbons in the Carver Amazings. It tears quite easily.
