Anyone know a good place to buy breaker boxes
polkfarmboy
polkfarmboy Posts: 5,703
I went to Menards and the prices are horrid so thought I would ask. This is not for an audio setup so does not have to be anything fancy
Post edited by polkfarmboy on
  • rpf65
    rpf65 Posts: 2,127
    edited August 2013
    Have you checked Lowes or Home Depot? Recommend GE, but that's a personal preference
  • nguyendot
    nguyendot Posts: 3,594
    edited August 2013
    Amazon
    Main Surround -
  • heartystatue
    heartystatue Posts: 329
    edited August 2013
    Might try Graingers.
    HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
    2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC.
  • zingo
    zingo Posts: 11,258
    edited August 2013
    Bingo
  • Inthefade
    Inthefade Posts: 180
    edited August 2013
    Lowes or Home Depot are most likely the cheaper option. Sometimes they have combo packs where you get a bunch of breakers with the panel.
    As far as quality is concerned a Square D QOB panel is top quality. All other panels are about the same quality.
    I'm not sure where your located but an electrical supply house is a good place to check prices. I buy a lot of electrical parts for work and granger is by far not the cheaper option for me.
  • decal
    decal Posts: 3,205
    edited August 2013
    F1nut Posts: 51,747
    edited August 2013
    Lowe's........Eaton/Cutler-Hammer CH version or for less money, the BR version.
  • Tornado Red
    Tornado Red Posts: 939
    edited August 2013
    I have an Eaton/CH panel like F1 mentioned, and the breakers are reasonably priced. Whatever you choose, it might be worth your while to check out what the breakers cost for the panel you're interested in first. Some panels have VERY high breaker prices that may scare you away from that particular box.
