Anyone know a good place to buy breaker boxes
Have you checked Lowes or Home Depot? Recommend GE, but that's a personal preference
AmazonMain Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Might try Graingers.HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC. -
Lowes or Home Depot are most likely the cheaper option. Sometimes they have combo packs where you get a bunch of breakers with the panel.
As far as quality is concerned a Square D QOB panel is top quality. All other panels are about the same quality.
I'm not sure where your located but an electrical supply house is a good place to check prices. I buy a lot of electrical parts for work and granger is by far not the cheaper option for me. -
You seem to have good luck on EBay, try there !!!!!!!! smiley_rotflmao.gifIf you can't hear a difference, don't waste your money.
Lowe's........Eaton/Cutler-Hammer CH version or for less money, the BR version.Political Correctness'.........defined
President of Club Polk -
I have an Eaton/CH panel like F1 mentioned, and the breakers are reasonably priced. Whatever you choose, it might be worth your while to check out what the breakers cost for the panel you're interested in first. Some panels have VERY high breaker prices that may scare you away from that particular box.
