Custom built crossover
Steven72555
Steven72555 Posts: 35
I have a crossover needs to be either replaced or repaired.
Anybody know where I can get this done?
I have the schematic and a pic of what I need.
    F1nut Posts: 52,366
    edited August 2013
    Was the speaker dropped?
    Anyway, the L1 inductor needs to have the one loose lead soldered back into its hole, which appears to be #1 on the board. Remove the old hot glue, solder the lead back it place, then resecure the inductor to the board with new hot glue. It's about 5 minutes worth of work.
    If you can't do it yourself, state where you live and perhaps one of us that can will live nearby. If you're near me I'll do it for free.
  • Steven72555
    edited August 2013
    I did it. It works fine now.
    But the other crossover has all the connections soldered where they need to be, I am not getting any lows out it at all. Think there is something blown?
    Oh, I live southeast of Cleveland Ohio.
    F1nut Posts: 52,366
    edited August 2013
    Ah, great!
    Ok, retouch all the solder joints on that board and check the lead connections on the woofer. If after that the woofer still isn't working, swap the known good woofer in its place.
    Ok, you and I aren't close enough.
  • Speedskater
    Speedskater Posts: 495
    edited August 2013
    Hey Steve, I'm in Lakewood (Cleveland West Side) and have been building & fixing electronic things since 1960. If you have anymore problems, let me know.
  • Steven72555
    edited August 2013
    Thanks, I will keep you in mind.
