New amp for my 2.3's
    F1nut Posts: 51,798
    edited August 2013
    trav0810 wrote: »
    No, the Tannoy is significantly higher.
    Sorry, I got side tracked by Monk's nonsense. That's interesting to say the least, I was betting the other way around. I'm not seeing anything special about the Tannoy. I'd say the seller is trying to ride the coat tails of the name they made for themselves with their speakers.
  • Habanero Monk
    Habanero Monk Posts: 715
    edited August 2013
    Here's a suggestion for you. When you have 3 guys in a thread stating that you are the problem, you should take that to heart and the next time consider that fact before hitting the keyboard. Let me say it again, you are the problem.
    All one has to do is look at the source(s). More signal less noise boys. The only thing looking Pro-Audio is the Tannoy. It's from around 1984, it's most likely from their pro-audio side of things and a A/B class amp. Nothing special about it and if paying more than $300 the OP is getting ripped off.
    Honestly the Adcom 5500 is probably worth $350 (I've seen the 5503 in pristine shape sell for $350-400) and the Tannoy about half that.
    Your notion of a suggested alternate given the OP's likely budget is just pretentious whining.
  • trav0810
    trav0810 Posts: 1,056
    edited August 2013
    Taste is subjective, I know that. A good friend of mine, who's opinion I respectable great deal has demo'd both amps and said "The Tannoy is what the Adcom dreams to be."
    But, like I said, it's all about synergy. And he is running a pair of Amazing Silvers which are a lot different from my SDA's. I do believe in he Tannoy has been recapped as well. But, for the price of the Tannoy, I could buy 2 5500,s. (the photo I posted of the Tannoy guts was a Web photo and not this uniit)
    The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
    Sony Playstation 3 for CD and Streaming
    Thorens TD320
    Modified Carver C-1
    Carver TFM 42 and 45 Amplifiers
    Polk RTA15TL Speakers w/Decato mods
    White Lightning Moonshine DIY Speaker Cables and Interconnects
  • Habanero Monk
    edited August 2013
    trav0810 wrote: »
    $600-800? Way too much. If that is your budget there is plenty of Parasound, Adcom, Rotel, etc for that.
  • erniejade
    erniejade Posts: 6,321
    edited August 2013
    While I like adcom and have owned a few of their amps, I find them a bit hot on the high end. I imagine the Tannoy is a bit smoother on top but, I would think the adcom has better bass control vs the tannoy just from the age and design. I could be wrong though since i havent heard the tannoy.
  • erniejade
    edited August 2013
    I agree with Habanero on this one. I would opt for a Parasound or Rotel for that $.
    F1nut Posts: 51,798
    edited August 2013
    I realize this may come as a shock to you because of your inexperience, but there's more to a good amp than that.
    More proof you're just here to argue.
  • Habanero Monk
    edited August 2013
    I was referring to the noise YOUR making in comparison to anything beneficial you have said. LOL. Your reading comprehension is terrible.
  • vmaxer
    vmaxer Posts: 5,120
    edited August 2013
    Make that 4 (FOUR) guys!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    F1nut Posts: 51,798
    edited August 2013
    It's YOU'RE as in YOU ARE.
    Sorry, it's your composition that is terrible. You should have composed your response as follows;
    "All one has to do is look at the source(s). More signal less noise boys.
    The only thing looking Pro-Audio is the Tannoy. It's from around 1984, it's most likely from their pro-audio side of things and a A/B class amp. Nothing special about it and if paying more than $300 the OP is getting ripped off."
    By separating your comments with a new paragragh instead of running them into each other you could have conveyed that your first sentence was a different topic. It's basic English 101, junior and YOU'RE still the problem.
    BTW, there's nothing pro audio looking about the Tannoy amp. Your lack of experience is showing again.
  • Habanero Monk
    edited August 2013
    I'll go with the slight grammatical error. That can be fixed. While your inability to actually read and comprehend is fortunately on public display.
    The fact that you guys are encouraging a ~30 year old or slightly younger amp at most likely $600-800 tells everyone here what they need to know.
  • Habanero Monk
    edited August 2013
    vmaxer wrote: »
    Four parrots in a row now.
  • Habanero Monk
    edited August 2013
    erniejade wrote: »
    You would figure at least one of the four Amigo's would have pointed that out first thing. I mean they are the brain trust around here :rolleyes:
    F1nut Posts: 51,798
    edited August 2013
    More deflection. Why is it so hard for you to admit you are the problem and seemingly can't be fixed.
    Wow, talk about reading comprehension problems, you take the cake. Where did I suggest (since you grouped everyone together) to the OP that he buy the Tannoy? Oh that's right, I didn't.
    YOU'RE still the problem, always have been.
  • vmaxer
    vmaxer Posts: 5,120
    edited August 2013
    Seem you can at least count¡¡¿¿„
    Oh, wait, I told you four didn't I.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Habanero Monk
    edited August 2013
    ZLTFUL wrote: »
    For the record, the link above was a simple single content type search using the keywords Crown and Yamaha and the user name Habanero Monk. The returns are a disturbingly large portion of his posts that interject these unsolicited options into threads over and over.
    And calling people liars for calling him out on it...the forum equivalent of, "Nana nana boo boo, stick your head in doo doo." Habanero Monk...keepin' it classy!
    You claimed I am 'touting' Yamaha, Crown, whatever. I asked you to back that up. You haven't. I don't remember if it's considered slander or libel :rolleyes:
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited August 2013
    I can't follow this thread....ah...the bozo list explains this....
  • Habanero Monk
    edited August 2013
    ZLTFUL wrote: »
    It's neither when it is true. Your legal knowledge is only rivaled by your audio knowledge. It isn't my fault that you are wrong.
    Technically, most if what you have posted in this thread against other members could be considered both.
    You still haven't backed up your original claim. More walk and less talk if you please. I Googled 'ZLTFUL + Ducati'. I can see how their ban on you is permanent. They seem a bit more lenient here when it came to your most recent.
  • Habanero Monk
    edited August 2013
    ZLTFUL wrote: »
    You have got to be kidding me. The only thing I directly said subjectively is that I 'like' my Yamaha. The fan not coming on or being quiet is simply a statement of fact.
    ZLTFUL wrote: »
    LOL: I said:
    quiet and more than suitable in room if you want and the aesthetic, while not beautiful, isn't garish either IMO.
    I run a Behringer EPX 2000 for my sub. It does a stellar job. It does. There are a good amount of people driving subs with Behringer with good results. It is a thread on specific pro-audio amps that have worked well. A resource of sorts. And why would you have a problem with that? I understand you are insecure and all that...
    The Yamaha isn't even that good looking according to my post.
    ZLTFUL wrote: »
    That is about the most effusive I get about the Yamaha. It's clean, it's quiet, good sound stage. It's also a response to someone asking about the Yamaha amp. I even said in thread If they don't work out just return the unit and get your money back I'm actually saying that a particular amp may not be for them.
    ZLTFUL wrote: »
    You even managed to drag an Emotiva thread down...and that is saying a LOT:
    http://www.polkaudio.com/forums/showthread.php?148717-Why-not-Emotiva&highlight=yamaha
    Zero touting in that thread. I do remember your rather odd claim that Emotiva was out there manipulating (hacking or paying off) other web sites to scrub any negative reviews.
    ZLTFUL wrote: »
    I use a Yamaha P2500S. It can be obtained for around $400 and I had zero risk in evaluating it since GC has a 30 day return policy. It replaced my Marantz Mono-blocks. Really allowed the Lsi 9's to open up
    ZLTFUL wrote: »
    So, would you care to retract your libelous statements where you called F1nut and I liars? Because the evidence above shows quite the contrary.
    No. You're still purposefully misrepresenting. And doing a pretty poor job of it. Touting would be saying it's the end all be all, that it's a giant killer, that it competes with stuff costing 10-20X it's costs. Me I'm saying try it out. It worked for me and most certainly use a place with an easy return policy because it may not be your cup of tea.
    That's easily readable in the links you provided. It's a balanced statement from me knowing that it's budget oriented solution.
    tonyb Posts: 33,072
    edited August 2013
    Ok you 2 yutes, put your big boy pants on and give it a rest already.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited August 2013
    Really give it a rest....
  • boston1450
    boston1450 Posts: 7,758
    edited August 2013
    Weiner waving. That there is funny ROLMAO
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited August 2013
    Already, come on its only been a little over a month :confused:
  • Huh What?
    Huh What? Posts: 55
    edited August 2013
    Trav - Have you spoken with a Tannoy dealer? I know Echo Audio in Portland, OR (www.echohifi.com) is a Tannoy dealer that also deals in used Adcom equipment. They may be uniquely suited to provide some insight specific to your original question.
    Home Theater - Talon Firebird (Fronts), Talon Raven 2002 (Surrounds), Talon Cinema Hawk (Ctr), Talon Falcon (Back Surrounds), JL Audio Fathom F112 Sub
    Pre/Pro - Classe SSP-800
    Amps - Sim Audio Moon Titan 5 channel, Modwright KWH 225i
    Blu-Ray - Oppo UDP-203
    Projector - Epson PowerLite Home Cinema 5040UB
    Screen - Silver Tickets MPT 110"
    Primary 2 Channel - Talon Firebirds
    Modwright KWH 225i Integrated Amp
    Oppo BDP-103, Audio Research DAC 8
    Secondary 2 Channel - Polk SDA 2B
    NAD T775, Denon 2900 DVD-A/SACD
  • trav0810
    edited August 2013
    Thanks for the tip. I'll give them a call later.
    Thorens TD320
    Modified Carver C-1
