Directions to fix an M5?
I need to know how to take the M5 apart and replace the driver? The part # is MW7008, does anyone know how or have instructions on how to do this? I can't figure out how to take the M5 apart.
Give CS a call, They'll hook you up..
I did call CS. They told me that the rep. said that they don't have directions with the replacement part. He recommended that I sent the speaker to the for repair. The cost makes that unreasonable to do for an 8 yr old speaker. This is a simple fix if I just knew how to get the speaker apart.
Try GENTLY prying off the grill.
I find it hard to beleive they told you that, but sent you the driver. Try to talk to Ken Swauger, and post this in Troubleshooting.
Good luck.. -
Hello,
The AWM5 is not an easy speaker to take apart for the owner. The front baffle (the support structure holding the tweeter and driver) fits into a channel that goes around the inside edge of the outer shell. If you're not very careful when you attempt prying the baffle away from the housing you can damage the housing, cracking the plastic enclosure. The other difficulty is that there is a water proof sealant that is applied, during manufacture, to prevent water from getting inside the speaker. So, for this reason we try and encourage owners to send the speaker into us, it's the one model that isn't easy for someone to repair themselves.
But, if you want to try you would remove the two Phillips head screws that are recessed into holes, on the back of the cabinet. You'll need a screw driver with a fairly long shaft to do this. Then you'll need a wide blade putty knife to begin levering the front baffle away from the shell of the enclosure. Work slowly, working first from the top, then the sides. The goal is to apply pressure over broad area to avoid cracking the case, placing the blade of the knife up underneath the front baffle's edge allowing the blade to come between the baffle and the inside of the shell. When you begin to get some separation to the top, begin working the sides, pulling the outer shell away to loosen the silicone sealant. Continue going around the circumference of the baffle/shell area using the putty knife to pull the shell away from the baffle's edges.
After the speaker has been opened up and repaired you will have to apply a bead of a silicone sealant to the inside of the shell so the baffle will be water proof when it is re-installed.
Keep in mind, we don't have any more of the replacement cabinets, for this speaker. So, be careful.
Regards, Ken -
Hi Ken,
Thanks for the reply. I work in Catonsville, MD so I am not far from the Polk main address. Can I drop the speaker off there for repair, & how much would it cost to repair it there? It is already costing me $ to have the replacement part sent to me, and I don't want to do more harm then good. -
Dude, I think the repairs are done in Cali. They might cut you a break, though.
You could do it, just take care IF you do.;) -
Actually I talked to a very nice woman in CS yesterday at the Main Office in Baltimore. She told me that when I get the replacement driver to bring it to the main office on Metro Dr. next week and they will do the repair as a courtesy to me for being a loyal customer. I always have loved this company & their products. Thanks for the replies.:D
