Mutual Coupling: What is it and how does it work?
Ty Burton
Hi guys, I'm new to this forum.
I've been doing a bit of research on subwoofers before I make the plunge and go for one and I am trying to at least get one subwoofer that can, or find a way of reaching the the 20hz bass range. After reading on the articles here on subwoofers it mentions about "Mutual Coupling", and that two subwoofers can in a way become one to create lower frequencies?
How does this work, is it only for DIY or can you place two subwoofers of the same model and brand together to make this work too?
It caught my attention because my budget is just a little over £200, but I can get another sub later on no problem if the "Mutual Coupling" thing is what I think it is
Post edited by Ty Burton on
Inductors with current flowing have a magnetic field around them. Place them too close together and the fields start to effect each other. This is generally consider negative and is to be avoided. I don't think that what your wanting here.
Acoustic coupling is when drivers are within a half a wavelength of each other where they begin to couple and act as one source. Search for that term to learn more.
CJ
PS...welcome to the forum!A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
Mutual coupling hmmmm sounds like " consenual sex " to me.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Ahh I see. I had a feeling there was a catch to what I took it as
I'll look up the term but this time "Acoustic Coupling". I might get better results than what I got with "Mutual Coupling".
Thanks.. -
Thanks..
"acoustic coupling " sounds like noisey sexMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
