Amp and Preamp diy designs or kits?
VR3
VR3 Posts: 29,444
edited July 2013 in DIY, Mods & Tweaks
I am curious to build an amp and a preamp or an integrated... Any leads on a solid design?
Post edited by VR3 on
  • Phasewolf
    Phasewolf Posts: 514
    edited July 2013
    How simple are you looking for and what do you want to spend?
    I have seen plans for class A per amps online before and even simple 5 watt class A amps.
    When I get home I will look to see what links I still have.
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
    VR3 Posts: 29,444
    edited July 2013
    I am open to anything... Looking for high end, something I can hand wire and use high quality parts
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited July 2013
    Diy audio sent an email a while back about a amp camp and kits.Might check them out.
    http://www.diyaudio.com/
    Dan
    nooshinjohn Posts: 25,932
    edited July 2013
    You are welcome to use my schematic. I can also get the transformers for you.
    EndersShadow Posts: 17,707
    edited July 2013
    Trey, here is some John found back in the day... they look quite intriguing and have a bunch of stuff to choose from
    AudioNote: http://www.ankaudiokits.com/index.html#prod_menu
    Original thread with some info: http://www.polkaudio.com/forums/showthread.php?141442-Audio-Note-Kits...-Anyone-have-opinions-or-experience-with-them
  • Drenis
    Drenis Posts: 2,871
    edited July 2013
    I threw the idea of building a pre-amp and DAC for me down the road but I'm not sure I have enough knowledge of the micro components that would be needed or enough technical knowledge to take on such a project. I looked at it as a way to get higher end components for a fraction of the cost if I could build something. Perhaps I dont give myself enough credit.
    Definitely be following where you go with this Trey.
  • Speedskater
    Speedskater Posts: 495
    edited July 2013
    The above listed (post #4) DIY Audio forum, has a huge number of different projects. From tubes to transistors to chip amps to class 'D' to Nelson Pass unit. A very are semi-built units, many are complete kits, others are printed circuit boards only and for the reminder you are on your own.
    One rambling thread about a high-end pre-amp for-which parts are no longer available is approaching some 40,000 posts.
  • Big Dawg
    Big Dawg Posts: 2,005
    edited July 2013
    I've been looking at these dynaco based kits. Some are substantially advanced beyond the original Haflef designs.
    http://www.tubes4hifi.com/home.html
    SCompRacer Posts: 9,112
    edited July 2013
    If you are interested I've got an assembled diy Pass Zen balanced linestage I am considering selling. It could be upgraded with exotic parts if desired but sounds very good as is. I bought it here as needing further completion.
    http://www.polkaudio.com/forums/showthread.php?144542-Feeler-Nelson-Pass-Balanced-Zen-Line-Stage
    My owner completion thread below. Both balanced inputs and four SE inputs are now connected to selector. I just left it with one pair of balanced and SE outputs connected. It is a quiet and great sounding pre; I used it as balanced. Comes with another unused/untested PS board.
    http://www.polkaudio.com/forums/showthread.php?147377-Pass-Zen-Owner-Completion&highlight=pass+zen
    I re-furbed a Krell KSL pre with a nice built in phono and stayed with it. My Krell is manual volume too, no remote.
    edited July 2013
    ^Rich, I totally forgot you had that. If its still around if I ever get up there again I would love to look at it.
  • bikerboy
    bikerboy Posts: 1,231
    edited July 2013
    I built a Relaixed 2 preamp. Its remote controlled and balanced output only. It is very clean and pure sounding. About $400 for the kit not including the case.
    http://www.diyaudio.com/forums/solid-state/211341-relaixed2-diy-balanced-pre-amp-build-report.html
    http://www.eijndhoven.net/jos/relaixed2/index.html
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • zingo
    zingo Posts: 11,258
    edited July 2013
    The Nelson Pass stuff available on DIYaudio is very good.
