Amp and Preamp diy designs or kits?
VR3
I am curious to build an amp and a preamp or an integrated... Any leads on a solid design?
How simple are you looking for and what do you want to spend?
I have seen plans for class A per amps online before and even simple 5 watt class A amps.
When I get home I will look to see what links I still have.Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Legacy Audio Focus SE
Legacy Audio Silverscreen HD center
Polk F/X500i Rears
Parasound HCA-3500
Sunfire Grand Cinema
Behringer iNUKE NU6000DSP
Pair of CraigSUB SS-18.1 -
I am open to anything... Looking for high end, something I can hand wire and use high quality parts- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Diy audio sent an email a while back about a amp camp and kits.Might check them out.
http://www.diyaudio.com/
Dan -
You are welcome to use my schematic. I can also get the transformers for you.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Trey, here is some John found back in the day... they look quite intriguing and have a bunch of stuff to choose from
AudioNote: http://www.ankaudiokits.com/index.html#prod_menu
Original thread with some info: http://www.polkaudio.com/forums/showthread.php?141442-Audio-Note-Kits...-Anyone-have-opinions-or-experience-with-them"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I threw the idea of building a pre-amp and DAC for me down the road but I'm not sure I have enough knowledge of the micro components that would be needed or enough technical knowledge to take on such a project. I looked at it as a way to get higher end components for a fraction of the cost if I could build something. Perhaps I dont give myself enough credit.
Definitely be following where you go with this Trey. -
The above listed (post #4) DIY Audio forum, has a huge number of different projects. From tubes to transistors to chip amps to class 'D' to Nelson Pass unit. A very are semi-built units, many are complete kits, others are printed circuit boards only and for the reminder you are on your own.
One rambling thread about a high-end pre-amp for-which parts are no longer available is approaching some 40,000 posts. -
I've been looking at these dynaco based kits. Some are substantially advanced beyond the original Haflef designs.
http://www.tubes4hifi.com/home.html -
If you are interested I've got an assembled diy Pass Zen balanced linestage I am considering selling. It could be upgraded with exotic parts if desired but sounds very good as is. I bought it here as needing further completion.
http://www.polkaudio.com/forums/showthread.php?144542-Feeler-Nelson-Pass-Balanced-Zen-Line-Stage
My owner completion thread below. Both balanced inputs and four SE inputs are now connected to selector. I just left it with one pair of balanced and SE outputs connected. It is a quiet and great sounding pre; I used it as balanced. Comes with another unused/untested PS board.
http://www.polkaudio.com/forums/showthread.php?147377-Pass-Zen-Owner-Completion&highlight=pass+zen
I re-furbed a Krell KSL pre with a nice built in phono and stayed with it. My Krell is manual volume too, no remote.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
^Rich, I totally forgot you had that. If its still around if I ever get up there again I would love to look at it."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
I built a Relaixed 2 preamp. Its remote controlled and balanced output only. It is very clean and pure sounding. About $400 for the kit not including the case.
http://www.diyaudio.com/forums/solid-state/211341-relaixed2-diy-balanced-pre-amp-build-report.html
http://www.eijndhoven.net/jos/relaixed2/index.htmlMain system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
