Subs 1-10 or 2-8s
sugar shane
sugar shane Posts: 1
edited July 2004 in Car Subwoofer Talk
I have a Harley Dav. truck what do you think will sound better one
10 Momo or 2 Polk DB 8s. I have Polk Momo 5*7 s in the doors.
Alpine CD head and Audiobaun 50*4 Amp.
Post edited by sugar shane on
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2004
    Well it depends on your musical tastes. If you are into rap or music where bass is pretty much all there is to it then you should go with 2 8s which will have more surface area and move more air. If youre into rock, metal and sound quality then go with the single 10. It wont be as loud but will blend with the music a bit more equally. Plus it will be easier to install.
    Me personally, Id go with a Diamond Audio CM3 10D4 and give it 500 rms. That will a lot of bass for the inside of a truck and will be more musical rather than just all bass.
    However if youre wanting to listen to bass then go with 2 Diamond Audio CM3 8D4's and give em 400 rms each. That will be plenty loud.
  • Airplay355
    Airplay355 Posts: 4,298
    edited June 2004
  • Systems
    Systems Posts: 14,872
    edited June 2004
    I don't know what the subs xmax is but I'd imagin the momo has greater xmax.....making the displacement close....
    I'd go 1 10"
    Testing
    Testing
    Testing
  • exalted512
    exalted512 Posts: 10,734
    edited June 2004
    either way, they will probably be the same in SPL, the 2 8s would probably be a little louder...but 2 subs look much cooler than one:)
    -Cody
  • Airplay355
    edited June 2004
    not when they are 8's :( i happen to to be the owner of a not so impressive 8" sub lol
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited June 2004
    depends on the sub and the install. Ive had some 8's that sucked.- solo round 8's and some that have kicked azz... JL8wo
    dont knock it just cause its an 8.
    heck..3 8w6's would be a deadly combo with about 1000 w.
    and I dont like JL :)
  • Systems
    edited June 2004
    8's are very cabable subs.....the L78, W78, Tandband 8, JBL gti8, RE8.......all can blow your mind with 6-8 of them off 1000w-2000w
    I'd put 2 L7 8's in there.....amazing little guys
    or stick with the 10" idea
    Testing
    Testing
    Testing
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited July 2004
    The two L7 8's would look sweet too.
    -Jerry
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
  • MacLeod
    edited July 2004
    Yeah, I really like the L7s. They can handle a lot of power, will work in a very small enclosure and put out a lot of bump!
