Subs 1-10 or 2-8s
sugar shane
I have a Harley Dav. truck what do you think will sound better one
10 Momo or 2 Polk DB 8s. I have Polk Momo 5*7 s in the doors.
Alpine CD head and Audiobaun 50*4 Amp.
Post edited by sugar shane on
Well it depends on your musical tastes. If you are into rap or music where bass is pretty much all there is to it then you should go with 2 8s which will have more surface area and move more air. If youre into rock, metal and sound quality then go with the single 10. It wont be as loud but will blend with the music a bit more equally. Plus it will be easier to install.
Me personally, Id go with a Diamond Audio CM3 10D4 and give it 500 rms. That will a lot of bass for the inside of a truck and will be more musical rather than just all bass.
However if youre wanting to listen to bass then go with 2 Diamond Audio CM3 8D4's and give em 400 rms each. That will be plenty loud.polkaudio sound quality competitor since 2005
1 10"
I don't know what the subs xmax is but I'd imagin the momo has greater xmax.....making the displacement close....
I'd go 1 10"Testing
Testing
Testing -
either way, they will probably be the same in SPL, the 2 8s would probably be a little louder...but 2 subs look much cooler than one:)
not when they are 8's
i happen to to be the owner of a not so impressive 8" sub lol -
depends on the sub and the install. Ive had some 8's that sucked.- solo round 8's and some that have kicked azz... JL8wo
dont knock it just cause its an 8.
heck..3 8w6's would be a deadly combo with about 1000 w.
and I dont like JL
8's are very cabable subs.....the L78, W78, Tandband 8, JBL gti8, RE8.......all can blow your mind with 6-8 of them off 1000w-2000w
I'd put 2 L7 8's in there.....amazing little guys
or stick with the 10" ideaTesting
Testing
Testing -
The two L7 8's would look sweet too.
-Jerry___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
Yeah, I really like the L7s. They can handle a lot of power, will work in a very small enclosure and put out a lot of bump!polkaudio sound quality competitor since 2005
