Rear surround positioning
bdtae5656
I've got a wall directly behind my listen area; So where should I have my rears pointed ? Im still breaking them in so I haven't watched any movies yet to really tell what sounds the best. If I knew how to attach a power point slide I'd be able to paint you guys a better picture of what my room looks like.
1. Pointed toward the fronts at a angle ?
2. Pointed toward the wall at an angle ?
3. Pointed directly toward my ears ?
TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Post edited by bdtae5656 on
Kinda' depends on how far in front of the rears are you seated when listening?Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
There on make sift stands until the Skylan's come inTV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables -
Id say a foot maybe foot and a 1/2TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Are the rear speakers being used in a 5.1 or 7.1 configuration?
Do your specific speakers have a built-in mounting bracket or screw holes?
I would place them on the sides of to the listening area if you are going to be using a 5.1 system. Either at ear level or higher.
If you are using these speakers in a 7.1 system to add depth then they should be behind the listening area. Or slightly behind and above the listening area. Your pictures show that you don't have room to place these speakers on stands behind the listening area. I would recommend that you mount them on your wall and angle them so that they fire sound down at the listening area.Polk R300 x2
Polk R150 x2
Polk CSR
Polk OWM3 x2
Polk PSW10
Onkyo HT-RC460
VideoSecu MS07B M99 x2 (Adjustable stands for the R150's)
