LSI-9 crossover upgrade - parts list?
ambiophonics
ambiophonics Posts: 727
edited July 2013 in DIY, Mods & Tweaks
I'm starting to set some money aside to upgrade the crossovers in my LSI-9s. I've read a great deal about different upgrade paths and preferences on specific cap and resistor brands but I haven't seen anyone lay out a specific parts list. I'd be doing these upgrades myself and as I work with electronics at my day job I can source whatever parts I need through my business. I'm not looking for the best money can buy, just recommendations of what works well and would provide a good benefit for the money.
A few specifics:
My main goals are more resolution of fine musical details and getting both speakers to have identical frquency response. I would assume the two speakers would become closer matched to each other with better crossover components that have tighter tolerances.
I'd like to stick with an electrolytic cap for the LF driver, possibly adding a bypass cap (if recommended) as I don't want to mess with the space or $$$ needed for the higher quality beer-can sized caps necessary to equal 260uf.
Some brands of resistors I've seen don't come in the 3 ohm value needed in this crossover, do you guys use 3.3 here or custom order the specific value needed? Possibly two 6 ohm resistors in parallel?
Inductors will stay stock
2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
Post edited by ambiophonics on
  • westmassguy
    westmassguy Posts: 6,850
    edited July 2013
    Not sure what your price range is, but Sonicaps will do nicely. Sonicraft also carries the 12 watt Mills Resistors in every value you'll need. The 260uf cap is a shunt, and doesn't require a bypass cap. I used NP Electrolytics to replace the 260uf caps in my SDA 2As, until I could afford Metalized Polypropylenes.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • ambiophonics
    edited July 2013
    Good info to know about the 260uf cap, I thought some people used an extra cap in that section for some reason.
  • westmassguy
    edited July 2013
    The only time you would use a bypass cap with an NP Electrolytic in a crossover, is when it's in series with the driver.
  • Face
    Face Posts: 14,340
    edited July 2013
    This is incorrect. Since amplifiers output AC voltage, everything matters.
  • westmassguy
    edited July 2013
    Face wrote: »
    So then what purpose does a bypass cap of higher quality serve on an NP Electrolytic shunt capacitor?
  • ambiophonics
    edited July 2013
    This discussion may get interesting...
  • sk88
    sk88 Posts: 159
    edited July 2013
    This description below makes a lot of sense to me. My personal experience has been that a bypass cap does change sound quality. However, it can be either positive or negative.
    http://www.diystompboxes.com/smfforum/index.php?topic=77762.0
    All real parts have non-perfect natures that prevent them acting like a textbook part. For instance, straight wires have inductance as well as resistance. As frequency rises, the resistance starts at the DC value, then starts rising as the skin effect forces charge carriers to the outside of the wire. Quite apart from the skin effect, the raw inductance starts to predominate at some high frequency and the impedance becomes the rising resistance caused by skin effect and the rising inductance of the wire.
    With that as a background, you can well imagine that something as complicated as an electro cap has even more imperfections in the real world. Electrolytic caps have Equivalent Series Resistance (ESR), which is the resistance of the parts getting charge into and out of the cap. Since they are made from thin (and resistive!) foils of aluminum wound up in a roll, there is a lot of thin metal to get through to get charge evenly distributed. They also leak a little, varying from one to the next. This is the Equivalent Parallel Resistance (EPR) and it becomes a problem with power supply caps as they get old. The winding of those foils in a bundle also adds inductance, the ESL. The bigger the capacitor, the bigger the ESL, in general.
    The capacitance causes a declining impedance of 1/(2*pi*F*C) until the size of the capacitive impedance equals the ESR. At thiat point, the impedance CAN'T get any lower, and the capacitor now looks to the outside world like a small resistance. Also, the impedance of the ESL is rising. At some frequency, it becomes bigger than the ESR. From that frequency on out to infinity, you now have an inductor, not a capacitor. The curve of impedance magnitude versus frequency is a V or a bathtub, depending on construction. Any one capacitor can only get so low in impedance.
    So how do you get low impedances at high frequencies? By using smaller capacitors in parallel. A smaller capacitor won't be as good as a bigger capacitance at low frequencies, but at some point, the smaller cap's lower ESL will let it go lower in impedance for higher frequencies than the bigger, but slower caps.
    Electro caps store a lot of charge down around DC, but they are getting inductive somewhere around the top of the audio range. If you either know what you're doing and know you need them, or have just read the buzz words from the cork sniffing elite, you will use a paralleled low ESR cap to help the poor fat electros out at high frequencies.
    There is one other instance where paralleled caps is slick and fairly elegant design work. Many active filters need frequency setting caps in the ratio of 1:2. It happens that the EIA standard set of capacitor values does not have many 2:1 ratio values. It is simpler and usually cheaper where you need two of one value and one of twice that value, to buy four caps of the same value, and parallel two of them for the twice-as-big cap.
    • Online - Focal Solo6 BE, Polk PSW10, Focusrite Saffire Pro 24 DSP, Lenovo x220t
    • Music/HT - Lsi25, Lsi9 (Vr3), Lsi7, LsiC, Pioneer SC-68 & BDP-62FD, PS3
