Fixing a cracked circuit board
kevhed72
kevhed72 Posts: 5,139
edited July 2013 in DIY, Mods & Tweaks
I have an older Pioneer tuner which appears to work, except there is a crack in the circuit board just before the Left and Right outputs (on the actual output circuits that carry the signal to the output RCA plugs).
I would like to fix this for use as my garage tuner....any suggestions?:question: thanks......:smile:
Post edited by kevhed72 on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited July 2013
    Hi,
    If the crack is to the board itself and the conductive trace is intact then you can use a good quality two-part epoxy to repair the break, holding the pieces together while the glue sets up. If the signal traces have broken then use small bits of insulated wire to complete the connection on either side of the break after the crack has been repaired.
    Ken
  • skrol
    skrol Posts: 3,440
    edited July 2013
    Good advice. If the trace is too difficult to solder wires on to, there is electrically conductive paint available. I had used this on a board that I had etched and needed to add a trace. They may even have it in marker form.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • westmassguy
    westmassguy Posts: 6,850
    edited July 2013
    skrol wrote: »
    Stan
    Depending on the size of the trace, you can also solder over the break. Once the glue or epoxy has set fully, you can clean the trace of any conformal coating or oxidation. Using a good quality solder like Cardas Quad Eutectic, you can flow a bead right over the break
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Phasewolf
    Phasewolf Posts: 514
    edited July 2013
    This is a case where a good pic would really help us help you.
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
