thoughts about equalisers and sound shapers
leftwinger57
I was just wondering about how improvement if any would a graphic equaliser or sound shaper make on a 2 chl system.We used to see them all the time SAE was famous for them and ADC plus many other brands. If, like I have the Onkyo P-301 pre and does a good job of dialing the sound your looking for are the equs any benifit for those finite adjustments or just another device in the stream clouding the mix.
I think EQs can be beneficial if you have severe room correction to deal with.
If you have a good neutral listening space, then I think they tend to add unwanted color.
Just my humble opinion."Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
I don't even have bass and treble controls on my 2 channel rig. Even when I did, I never used them. Always set everything to flat.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Just say no...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Evil, evil, evil. 'Nuff said.Political Correctness'.........defined
President of Club Polk -
DSP before D/A conversion is fine, anything afterwards raises the noise floor."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
+1 for no tone controls or EQ. If you don't like how your gear sounds, get different gear.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
I suspect you will see this become standard as time goes by even in two channel gear. Room correction software will help bring out the best in any room.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Gotcha, Mass unapproval. Never owned one and have 0 intention of getting one .Just wondering.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Mikey081057 wrote: »I don't even have bass and treble controls on my 2 channel rig. Even when I did, I never used them. Always set everything to flat.
I bet you might give these a try, bass and treble on the right.
http://www.dagostinoinc.com/Lumin X1 file player, Westminster Labs interconnect cable
Mixed feelings. My 2 channel doesn't have bass/treble. The real problem is what you think you hear that
is wrong. I have played with Foobar eq with headphones. I tried doing it by ear, and it didn't really work.
I then pulled out some posted charts of the frequency response, and that pinpointed an issue
at 9k. There was a nasty peak. Made the adjustment- all was good. EQ can be good, but most
people including myself have trouble pinpointing the problem bands to make the adjustments to."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
I'm going to boldly state that I love what my ADC Soundshaper III does to correct room and (sometimes) poorly mastered music. I've tried listening with all tone and EQ off but just end up finding it too flat and not lively enough. The traditional "happy face" curve on the equalizer makes the room sound more neutral. This is confirmed with a spectrum analyzer. I've set the room to dead neutral with the spectrum analyzer and it's close to what my ears prefer. The room also has some treatments but without the eq I'd be tweaking forever until I found what I liked. The ADC I'm using is very quiet and in my opinion takes nothing away. When I bypass it when it's set to neutral on all frequencies I can hear no change in sound whatsoever. I've never understood this trend toward no tone controls or sound shapers. When used correctly and with good quiet equipment they can add greatly to one's musical enjoyment. Flame ON!!!!SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
I've used mine for years, no intention of not using it.
Exactly, it's a "more harm than good" scenario 90% of the time; AND it's adding another box full of electronics in the chain.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
Once again it's a tool. Not always the right tool for the job. And don't cut
off a finger using it."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
I use one but think of it as using spice on good chow...a little improves the taste...too much ruins it!
Bingo....though I can understand why some want to use one. A cheap alternative to switching out gear. Back in the day, I was always having to adjust mine with almost every song. One setting would sound good on a certain recording but horrible on another. Pain in the arse if you ask me and worth less than a paper weight these days.HT SYSTEM-
lsi 9's -
Rule#1....do no harm
Rule#2 ...the more buttons, switches and knobs, generally, the worse it sounds (George Grand, of the Jersey Grands)I plan for the future. - F1Nut -
Rule #2 is somewhat true....in the world of 2 channel anyway.
When you look at some higher end processors from Anthem,Cary and the likes, you see lots of buttons but SQ certainly is no slouch even for 2 channel.
Rule #1 should be....if you like what you hear, leave it the f#$k alone. :cheesygrin:HT SYSTEM-
lsi 9's -
But some of them had really cool multicoloured lights that bounce or dance with the music, lol
I think they called them Spectrum Analyzers then I thought they were really cool but I have Grown since then,lol
Just food for thought, if you like the way it makes your music sound then use it that's all that matters, your Ears..Evil, evil, evil. 'Nuff said.ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
Rule #1: There is no rule :cheesygrin: if you like what you hear in your system, then go for it
Would it be fair to say you can draw a line between traditional analogue equalisers and those that operate in the digital domain, like MiniDSP, Dspeaker anti-mode and some of the Behringer products? I recently used REW to identify some suspected room modes giving me trouble and now want to try some room correction. I didn't even consider using an old school equaliser, not wanting to add more stuff in the chain as others have mentioned, but I'm leaning towards the MiniDSP OpenDRC-DI for an all digital solution.2 CH - SB Touch, CA 840C, CA 840Av2, PSB Imagine T
HT - Pioneer 1325, Emo UPA-1, MA Silver RS series 7.1 -
Correct you are sir... If you have a spare on laying around send it may way... I will even pay fedex overnite. They were on the cover of one of the audio rags, and it is **** for sure.My New Year's resolution is 3840 × 2160
I am actually getting my dads adc sound shaper 2 soon. Looking forward to learning with it. I currently have been using rew to help with room correction through my pc and plan on getting a mini dsp for everything else.
The whole eq thing is new to me and having physical sliders will help me learn easier what sounds/instruments are in what freq range.I have heard that people run the we in the tape loop, so they can engage it or listen to straight. Plus all the rows of leds is pretty cool looking.HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator -
I run an SAE parametric EQ. I've run eq's in my system since the 80's and I wouldn't go without one. Running things flat just sounds.....flat. I like to spice it up.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
Would it be fair to say you can draw a line between traditional analogue equalisers and those that operate in the digital domain, like MiniDSP, Dspeaker anti-mode and some of the Behringer products? I recently used REW to identify some suspected room modes giving me trouble and now want to try some room correction. I didn't even consider using an old school equaliser, not wanting to add more stuff in the chain as others have mentioned, but I'm leaning towards the MiniDSP OpenDRC-DI for an all digital solution."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Behringer's DSP amps use the cheapest DSP chips available, I'd avoid them. MiniDSP can sound good if you feed it a digital signal and know what you're doing. If you have a room with bass trouble, multiple subs is your answer: http://www.harman.com/EN-US/OurCompany/Innovation/Documents/White%20Papers/multsubs.pdf If you absolutely need EQ bass frequencies, get a sub and amp with a lot of headroom.
+1. From my very limited experience, this did make things much easier for me in my large room for 2 channel. However, I do want to explore multeq xt32 or an add-on bass management to see if I can improve further._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
Face, thanks for the link, interesting read. In my case my 2 channel rig is in the living room so even one sub is probably out of the question, let alone multiples. I think I'll be ordering an OpenDRC-DI to play with this winter.2 CH - SB Touch, CA 840C, CA 840Av2, PSB Imagine T
