SRT System For Sale on A'gon
Mike Reeter
Mike Reeter Posts: 4,315
edited July 2013 in Vintage Speakers
Don't know if these have been mentioned here before or not, thought they might be of interest to some.
http://app.audiogon.com/listings/full-range-polk-srt-speaker-system-srt-complete-system-2013-07-16-speakers-98011-bothell-wa
Post edited by Mike Reeter on
  • vmaxer
    vmaxer Posts: 5,121
    edited July 2013
    I wish I could!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Gatecrasher
    Gatecrasher Posts: 1,538
    edited July 2013
    Looks like it might be a scam.
    They are being "auctioned" on eBay at the same time.
  • oldmodman
    oldmodman Posts: 740
    edited July 2013
    Looks like this set doesn't include the rear channel speakers.
    But it will most likely be an incredible deal for someone local. I bet the shipping and crating could go many hundreds of dollars if they have to be shipped.
  • Mike Reeter
    edited July 2013
    Yeah, I noticed ZERO feedback on the seller, could be one to steer clear of.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2013
    There's a set in Chicago for $1700.
  • zingo
    zingo Posts: 11,258
    edited July 2013
    The seller lives in the same town as I do, so I sent him a message this morning asking if I can check them out.
  • zingo
    zingo Posts: 11,258
    edited July 2013
    The Audiogon and Ebay list different cities, although they are within 15 minutes of eachother...
    pitdogg2 Posts: 27,317
    edited July 2013
    zingo wrote: »
    Correct but same verbiage in both ad's hence I would draw the same conclusion "same guy"
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited July 2013
    Are these srt systems good in comparison to todays offerings? All them woofers on them speakers, I bet the mids are clear as day
  • zingo
    zingo Posts: 11,258
    edited July 2013
    Never heard back from the seller after sending them an email, but I did just get this message...
    SRT.jpg 27.9K
    F1nut Posts: 52,000
    edited July 2013
    Capable of 125dB with SDA........they effing rock!
  • ESavinon
    ESavinon Posts: 3,067
    edited July 2013
    I've done 129db with SDA at 3 meters.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • dpowell
    dpowell Posts: 3,081
    edited July 2013
    This set has the rear channel SDA's which is a rarity to find. It only mentions one controller and I believe a second controller was required for the rear channels? They do rock for HT but IMO lack the musicality that the more vintage SDA's have....hence my decision to sell my SRT's and go with the 2.3TL's. A good sub (i.e. an SVS in my case) blends quite well and provides more than ample bass for HT.
    It's impressive that the SRT's can do 129db but the reality is that if you listen to them that loud, you may not be able to hear them for long! :eek:
    If anyone buys these, check the subwoofers carefully. The drivers had a problem where in many cases the spiders detached and had to be glued back in place.....and be sure you have a real amp to drive the mains. They are power hungry and never satisfied.
    F1nut Posts: 52,000
    edited July 2013
    ESavinon wrote: »
    Impressive!
    nooshinjohn Posts: 26,001
    edited July 2013
    And a no sell with a high bid of just 338 bucks.
  • vmaxer
    vmaxer Posts: 5,121
    edited July 2013
    I would love to try some one day.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
