thoughts about equalisers and sound shapers
leftwinger57
leftwinger57 Posts: 2,917
edited July 2013 in 2 Channel Audio
I was just wondering about how improvement if any would a graphic equaliser or sound shaper make on a 2 chl system.We used to see them all the time SAE was famous for them and ADC plus many other brands. If, like I have the Onkyo P-301 pre and does a good job of dialing the sound your looking for are the equs any benifit for those finite adjustments or just another device in the stream clouding the mix.
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited July 2013
    I don't even have bass and treble controls on my 2 channel rig. Even when I did, I never used them. Always set everything to flat.
    Garage | Polk Monitor 5B's
    nooshinjohn Posts: 25,899
    edited July 2013
    Just say no...
    F1nut Posts: 51,713
    edited July 2013
    Evil, evil, evil. 'Nuff said.
  • Face
    Face Posts: 14,340
    edited July 2013
    DSP before D/A conversion is fine, anything afterwards raises the noise floor.
  • nspindel
    nspindel Posts: 5,343
    edited July 2013
    +1 for no tone controls or EQ. If you don't like how your gear sounds, get different gear.
  • BlueFox
    BlueFox Posts: 15,251
    edited July 2013
    Face wrote: »
    I suspect you will see this become standard as time goes by even in two channel gear. Room correction software will help bring out the best in any room.
  • leftwinger57
    edited July 2013
    Gotcha, Mass unapproval. Never owned one and have 0 intention of getting one .Just wondering.
  • BlueFox
    edited July 2013
    I bet you might give these a try, bass and treble on the right.
    http://www.dagostinoinc.com/
  • sucks2beme
    sucks2beme Posts: 5,681
    edited July 2013
    Mixed feelings. My 2 channel doesn't have bass/treble. The real problem is what you think you hear that
    is wrong. I have played with Foobar eq with headphones. I tried doing it by ear, and it didn't really work.
    I then pulled out some posted charts of the frequency response, and that pinpointed an issue
    at 9k. There was a nasty peak. Made the adjustment- all was good. EQ can be good, but most
    people including myself have trouble pinpointing the problem bands to make the adjustments to.
  • Fongolio
    Fongolio Posts: 3,516
    edited July 2013
    I'm going to boldly state that I love what my ADC Soundshaper III does to correct room and (sometimes) poorly mastered music. I've tried listening with all tone and EQ off but just end up finding it too flat and not lively enough. The traditional "happy face" curve on the equalizer makes the room sound more neutral. This is confirmed with a spectrum analyzer. I've set the room to dead neutral with the spectrum analyzer and it's close to what my ears prefer. The room also has some treatments but without the eq I'd be tweaking forever until I found what I liked. The ADC I'm using is very quiet and in my opinion takes nothing away. When I bypass it when it's set to neutral on all frequencies I can hear no change in sound whatsoever. I've never understood this trend toward no tone controls or sound shapers. When used correctly and with good quiet equipment they can add greatly to one's musical enjoyment. Flame ON!!!!
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • chungasrevenge
    chungasrevenge Posts: 19
    edited July 2013
    I've used mine for years, no intention of not using it.
  • steveinaz
    steveinaz Posts: 19,545
    edited July 2013
    Exactly, it's a "more harm than good" scenario 90% of the time; AND it's adding another box full of electronics in the chain.
  • sucks2beme
    edited July 2013
    Once again it's a tool. Not always the right tool for the job. And don't cut
    off a finger using it.
  • Msabot1
    Msabot1 Posts: 2,098
    edited July 2013
    I use one but think of it as using spice on good chow...a little improves the taste...too much ruins it!
    tonyb Posts: 33,069
    edited July 2013
    steveinaz wrote: »
    Bingo....though I can understand why some want to use one. A cheap alternative to switching out gear. Back in the day, I was always having to adjust mine with almost every song. One setting would sound good on a certain recording but horrible on another. Pain in the arse if you ask me and worth less than a paper weight these days.
  • TroyD
    TroyD Posts: 13,124
    edited July 2013
    Rule#1....do no harm
    Rule#2 ...the more buttons, switches and knobs, generally, the worse it sounds (George Grand, of the Jersey Grands)
    tonyb Posts: 33,069
    edited July 2013
    Rule #2 is somewhat true....in the world of 2 channel anyway.
    When you look at some higher end processors from Anthem,Cary and the likes, you see lots of buttons but SQ certainly is no slouch even for 2 channel.
    Rule #1 should be....if you like what you hear, leave it the f#$k alone. :cheesygrin:
  • Jhayman
    Jhayman Posts: 1,548
    edited July 2013
    But some of them had really cool multicoloured lights that bounce or dance with the music, lol
    I think they called them Spectrum Analyzers then I thought they were really cool but I have Grown since then,lol
    Just food for thought, if you like the way it makes your music sound then use it that's all that matters, your Ears..
  • brianle
    brianle Posts: 572
    edited July 2013
    Rule #1: There is no rule :cheesygrin: if you like what you hear in your system, then go for it
  • bmor
    bmor Posts: 44
    edited July 2013
    Would it be fair to say you can draw a line between traditional analogue equalisers and those that operate in the digital domain, like MiniDSP, Dspeaker anti-mode and some of the Behringer products? I recently used REW to identify some suspected room modes giving me trouble and now want to try some room correction. I didn't even consider using an old school equaliser, not wanting to add more stuff in the chain as others have mentioned, but I'm leaning towards the MiniDSP OpenDRC-DI for an all digital solution.
    2 CH - SB Touch, CA 840C, CA 840Av2, PSB Imagine T
    HT - Pioneer 1325, Emo UPA-1, MA Silver RS series 7.1
  • Mikey081057
    edited July 2013
    BlueFox wrote: »
    Correct you are sir... If you have a spare on laying around send it may way... I will even pay fedex overnite. They were on the cover of one of the audio rags, and it is **** for sure.
  • specd_out
    specd_out Posts: 505
    edited July 2013
    I am actually getting my dads adc sound shaper 2 soon. Looking forward to learning with it. I currently have been using rew to help with room correction through my pc and plan on getting a mini dsp for everything else.
    The whole eq thing is new to me and having physical sliders will help me learn easier what sounds/instruments are in what freq range.I have heard that people run the we in the tape loop, so they can engage it or listen to straight. Plus all the rows of leds is pretty cool looking.
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • joeparaski
    joeparaski Posts: 1,865
    edited July 2013
    I run an SAE parametric EQ. I've run eq's in my system since the 80's and I wouldn't go without one. Running things flat just sounds.....flat. I like to spice it up.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • Face
    Face Posts: 14,340
    edited July 2013
    bmor wrote: »
    Behringer's DSP amps use the cheapest DSP chips available, I'd avoid them. MiniDSP can sound good if you feed it a digital signal and know what you're doing. If you have a room with bass trouble, multiple subs is your answer: http://www.harman.com/EN-US/OurCompany/Innovation/Documents/White%20Papers/multsubs.pdf If you absolutely need EQ bass frequencies, get a sub and amp with a lot of headroom.
  • Thorton
    Thorton Posts: 1,324
    edited July 2013
    Face wrote: »
    +1. From my very limited experience, this did make things much easier for me in my large room for 2 channel. However, I do want to explore multeq xt32 or an add-on bass management to see if I can improve further.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • bmor
    bmor Posts: 44
    edited July 2013
    Face, thanks for the link, interesting read. In my case my 2 channel rig is in the living room so even one sub is probably out of the question, let alone multiples. I think I'll be ordering an OpenDRC-DI to play with this winter.
