How To Hook up Monitor 55T Speakers to a 7.1 Amp
aries1969
aries1969 Posts: 1
edited July 2013 in Speakers
hello i just bought these speakers and i have a 7.1 amp and want to use all 7 speakers and would like to know wich set of posts do i use on the speakers and thank you
Post edited by aries1969 on
    F1nut Posts: 51,798
    edited July 2013
    You're not being very clear on what you want to know. Do you have other speakers or just the pair of Monitor 55T's? You do not have a 7.1 amp, you have an AVR that is capable of 7.1. It doesn't matter if you connect the speaker cables to the top or bottom set of posts as long as the jumpers are in place.
  • Mystery
    Mystery Posts: 2,546
    edited July 2013
    I think he is asking on the back of the speakers.
    If there are jumpers connected, it doesn't matter. Just think them as one pair of terminals, not two.
    Just use positive from amp to positive and negative to negative for one channel (FL or FR etc.)
    If jumpers are missing, you have to connect those two terminals somehow.
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2013
    Just hook black to black and red to red. If your speakers are new they will work. Don't remove anything from the terminals. Even easier if you use banana plugs, just plug them into any black/red on the back of the speaker without untightening them.
    Main Surround -
