Running 4-conductor wire to speakers - best way?
scubalab
scubalab Posts: 3,105
It may have been discussed before, but couldn't find an exact answer in what I've read so far...
All of the speakers in my HT have the double set of binding posts for bi-wiring or bi-amping. I don't believe I can bi-amp, but was wondering the best way to wire them. I have in-wall 12AWG 4-conductor wire goint to each speaker. At the receiver (Denon AVR-988), i have both reds in one banana plug and both blacks in the other banana plug. The question is, would it be better to do the same at the speakers (with a good jumper between the binding posts), or skip the jumper and connect the four wires to the four binding posts? Or do you think it would even make a difference??
Post edited by scubalab on
    pitdogg2 Posts: 27,196
    edited July 2013
    scubalab wrote: »
    This if you going to do it. It may or may not make a difference and can't hurt...
  • Glen B
    Glen B Posts: 269
    edited July 2013
    I would not waste the time. I doubt you would hear any worthwhile difference, especially with mass market gear. Even with high end gear, its doubtful. I've been there, done that. Even if you could get some benefits from biwiring, the extra cable from in-wall runs, plus multiple connection points, would probably cancel out any improvements. Why did you have 4-conductor cable runs to each speaker installed ? That was a waste of money versus 2-conductor.
  • scubalab
    edited July 2013
    Figured It'd be a heck of a lot easier to run the 4 conductor wire and not need it than find out after the drywall was repaired that I might want to bi-amp, or upgrade... The wire (from Monoprice) was not that much more (I think around $40 or $50 more at the time I purchased/installed).
  • scubalab
    edited July 2013
    Thanks. That's what I figured...
