Beginner needing some HELP
moby63
moby63 Posts: 2
edited July 2013 in Speakers
I want upgrade my speaker system from SVS SBS-01 Speaker System
http://www.hometheater.com/content/svs-sbs-01-speaker-system-and-pioneer-vsx-1017txv-k-av-receiver-glance-ratings-svs
to
rti a7 or rti a9 and CSI A6
Onkyo TX-NR818
OPPO BDP-93
Sharp AQUOS LC-80LE844U
Thx for help
Post edited by moby63 on
  • BlueFox
    BlueFox Posts: 15,251
    edited June 2013
    Sure. Go ahead. Glad to help. :smile:
  • heartystatue
    heartystatue Posts: 329
    edited June 2013
    Welcome to CP. If you do some reading around here that question has been brought up quite a bit. From what I have read either way you should add a sub especially if your using strictly for HT. Either way, going the polk route is an upgrade. Good luck.
    HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
    2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC.
  • theshawn
    theshawn Posts: 70
    edited July 2013
    Going the Polk route is an upgrade from what? Other mass marketed speakers? :cheesygrin:
    F1nut Posts: 51,674
    edited July 2013
    The RTi A9's need a power amp to drive them. The RTi A7's will work much better with your AVR.
  • moby63
    moby63 Posts: 2
    edited July 2013
    I just ordered the rti a9 and the csi a 6 and xpa 3 I will keep my sub svs PB10-NSD and the sbs 02 for the rear channels
    some settings tips will help
    thanks
