Wireless F/X surround whistle noise on shutdown
harv
harv Posts: 1
edited July 2013 in Troubleshooting
Hi all,
I just purchased a wireless F/X surround speaker. A problem - when I power down my home theater system, the F/X makes a very irritating whistling noise - like a bomb dropping in an vintage WWII film. My wife and cat both don't like this, and I may have to return the F/X if it can't be resolved.
I should note that I am using an Outlaw Model 7125 amplifier. Would it help if I use the line out from the AV receiver/preamp (an Outlaw 990)? But would that affect the sound quality?
Thanks much.
Post edited by harv on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited July 2013
    Hello harv,
    Thanks for posting on Polk's forum. Give Polk's CS guys a call at 1-800-377-7655, they'll be able to offer some help.
    Regards, Ken
  • Syndil
    Syndil Posts: 1,582
    edited July 2013
    Harv, the sound you describe is likely caused by your Outlaw amplifier's capacitors discharging when you power it off. It's actually a fairly common question here, not specific to the F/X surround. If you connect the F/X surround directly to your 990 (great pre/pro; I also have one) you should avoid that problem, and I believe the sound quality will be just as good or better.
