Connecting Spades
rlam01
How the devil does one connect the spades to the binding posts?
I can see how pin type, bare wire and bannana connectors go but the spades are not so clear.
Center-CSI3 Mains-R50 Rears-R30
Sub-PSW303 Receiver-Integra 5.4 DTR
HDTV-JVC AV48WP74
---- Fight On!----
HDTV-JVC AV48WP74
---- Fight On!----
Post edited by rlam01 on
It should be sorta obvious. It is possible your spade has too small a diameter.
You loosen the terminal on the binding post and seat the spade beneath the binding post cap with the spades to either side of the post. Sorta like when a woman wraps her legs around your neck
Tighten the cap back down and your done. If your spade won't fit around the post you need a bigger spade.
If the womans legs won't fit around your neck, you need a bigger woman.The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
This is pretty f***ed up right here. -
When you loosen the red/black cap, the post (a cylinder with a hole running through it) is revealed. It does not look like a solid vertical column that I could insert the spade around.
Am I supposed to keep turning the cap to reveal something else?Center-CSI3 Mains-R50 Rears-R30
HDTV-JVC AV48WP74
---- Fight On!---- -
that hollow post is what the spade goes around then screw the top back on
Thanks.
In retrospect, I should have clarified my post a bit more. I am going to purchase new cables. Currently I have speaker cable that is unterminated. I just stripped the end and inserted the bare wire.
I have NOT personally seen how big a spade is. For whatever reason (which was wrong), I assummed that a spade would be very small. However, if they are supposed to go around the post, then "small" is not how I should have envisioned them.
And here I thought "newbie" was a thing of the past for me.
HDTV-JVC AV48WP74
