Playing music from iTunes on my 2-channel stereo.
ipsullivan
As the title says, what is my best option to play my iTunes library on my 2-channel stereo? I am currently using a Yamaha HTR-5860 as a pre-amp, ADCOM GFA-5500, and a pair of RTA 11Ts.
My computer has an HDMI out, I know there are a few companies that make a splitter to pull the audio out from HDMI. Would this be a viable option? Will my computer limit the quality?
Any help or suggestions would be much appreciated.
Thanks,
Ian
Thanks,
Ian
Post edited by ipsullivan on
I use an airport express to transmit wirelessly and use an optical cable from the airport express into my receiver. Sounds pretty good to me and fairly inexpensive.
ipsullivan wrote: »Will my computer limit the quality?
Yes and no.....ITunes alone will limit the quality to some degree. If you go this route just make sure you use apple lossless when downloading music files.HT SYSTEM-
lsi 9's -
If I use iTunes, I use Apple lossless and stream through my Squeezebox. After reading some posts here I think JRiver would likely be a better alternative.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Your lucky w/ HDMI ,I have a 10y/o Gateway that I use the headphone jack > a double splitter 1. side to keep in my room 2nd to run into a Y splitter w/ mini jack male > rca to my Yamaha then out of the avr into the tuner input of my Onkyo pre/amp .Very convoluted but it does work.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
You cannot download lossless files from iTunes the store. They only sell lossy files. If you want lossless files then you need to use iTunes the software and copy CDs using Apple Lossless.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Yes of course.....maybe I should have added..."...from your cd collection".....at the end of that.HT SYSTEM-
lsi 9's -
You can find an AIOS for $70 when they go on sale. I used one for a little while as a media player, but switched to Dune media players. I've never really tried to use a media player for music.AVR: DENON X4000
FRONT L/R: ARX A3RX-C
CENTER: ARX A2RX-C
SURROUND L/R: ARX A3
SUBWOOFER: PSA-XV15
SERVER: UNRAID 15TB
MEDIA PLAYERS: DUNE SMART SERIES D1
HDTV: VIZIO M601D-A3R -
I use a High Resolution Technologies Music Streamer II+ DAC which uses USB signal and power, then analog interconnects from it to the preamp. This system works great. I also use VLC as a player rather than itunes. VLC will play FLAC files, where itunes will not. There are several options for a player that are better than itunes.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com
