Playing music from iTunes on my 2-channel stereo.
ipsullivan
ipsullivan Posts: 65
edited August 2013 in Going Digital
As the title says, what is my best option to play my iTunes library on my 2-channel stereo? I am currently using a Yamaha HTR-5860 as a pre-amp, ADCOM GFA-5500, and a pair of RTA 11Ts.
My computer has an HDMI out, I know there are a few companies that make a splitter to pull the audio out from HDMI. Would this be a viable option? Will my computer limit the quality?
Any help or suggestions would be much appreciated.
Thanks,
Ian
Post edited by ipsullivan on
  • simm
    simm Posts: 602
    edited July 2013
    I use an airport express to transmit wirelessly and use an optical cable from the airport express into my receiver. Sounds pretty good to me and fairly inexpensive.
    tonyb Posts: 33,072
    edited July 2013
    ipsullivan wrote: »
    Yes and no.....ITunes alone will limit the quality to some degree. If you go this route just make sure you use apple lossless when downloading music files.
  • zane77
    zane77 Posts: 1,696
    edited July 2013
    If I use iTunes, I use Apple lossless and stream through my Squeezebox. After reading some posts here I think JRiver would likely be a better alternative.
    Two Channel
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited July 2013
    Your lucky w/ HDMI ,I have a 10y/o Gateway that I use the headphone jack > a double splitter 1. side to keep in my room 2nd to run into a Y splitter w/ mini jack male > rca to my Yamaha then out of the avr into the tuner input of my Onkyo pre/amp .Very convoluted but it does work.
  • BlueFox
    BlueFox Posts: 15,251
    edited July 2013
    tonyb wrote: »
    You cannot download lossless files from iTunes the store. They only sell lossy files. If you want lossless files then you need to use iTunes the software and copy CDs using Apple Lossless.
    tonyb Posts: 33,072
    edited July 2013
    BlueFox wrote: »
    Yes of course.....maybe I should have added..."...from your cd collection".....at the end of that.
  • GFOviedo
    GFOviedo Posts: 353
    edited July 2013
    You can find an AIOS for $70 when they go on sale. I used one for a little while as a media player, but switched to Dune media players. I've never really tried to use a media player for music.
    AVR: DENON X4000
    FRONT L/R: ARX A3RX-C
    CENTER: ARX A2RX-C
    SURROUND L/R: ARX A3
    SUBWOOFER: PSA-XV15
    SERVER: UNRAID 15TB
    MEDIA PLAYERS: DUNE SMART SERIES D1
    HDTV: VIZIO M601D-A3R
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited August 2013
    I use a High Resolution Technologies Music Streamer II+ DAC which uses USB signal and power, then analog interconnects from it to the preamp. This system works great. I also use VLC as a player rather than itunes. VLC will play FLAC files, where itunes will not. There are several options for a player that are better than itunes.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
