Connecting Spades
rlam01
rlam01 Posts: 38
How the devil does one connect the spades to the binding posts?
I can see how pin type, bare wire and bannana connectors go but the spades are not so clear.
Center-CSI3 Mains-R50 Rears-R30
Sub-PSW303 Receiver-Integra 5.4 DTR
HDTV-JVC AV48WP74
---- Fight On!----
Post edited by rlam01 on
  • Zen Dragon
    Zen Dragon Posts: 501
    edited June 2004
    It should be sorta obvious. It is possible your spade has too small a diameter.
    You loosen the terminal on the binding post and seat the spade beneath the binding post cap with the spades to either side of the post. Sorta like when a woman wraps her legs around your neck :p
    Tighten the cap back down and your done. If your spade won't fit around the post you need a bigger spade.
    If the womans legs won't fit around your neck, you need a bigger woman.
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
    This is pretty f***ed up right here.
  • rlam01
    rlam01 Posts: 38
    edited June 2004
    When you loosen the red/black cap, the post (a cylinder with a hole running through it) is revealed. It does not look like a solid vertical column that I could insert the spade around.
    Am I supposed to keep turning the cap to reveal something else?
    HDTV-JVC AV48WP74
    ---- Fight On!----
  • Willow
    Willow Posts: 11,223
    edited June 2004
    that hollow post is what the spade goes around then screw the top back on
  • rlam01
    rlam01 Posts: 38
    edited June 2004
    Thanks.
    In retrospect, I should have clarified my post a bit more. I am going to purchase new cables. Currently I have speaker cable that is unterminated. I just stripped the end and inserted the bare wire.
    I have NOT personally seen how big a spade is. For whatever reason (which was wrong), I assummed that a spade would be very small. However, if they are supposed to go around the post, then "small" is not how I should have envisioned them.
    And here I thought "newbie" was a thing of the past for me. :D
    HDTV-JVC AV48WP74
    ---- Fight On!----
