Help!! BadPioneer vsx-820 microphone
Danny mc
Danny mc Posts: 24
edited July 2013 in Electronics
Need to replace my microphone to set up my surround ht..any ideas and is there a generic one I could find cheaper???
Post edited by Danny mc on
    F1nut Posts: 51,995
    edited July 2013
    Call Pioneer.
    edited July 2013
    ...or you could just do it manually. Even after using the mic, you still need to tweek things anyway.
  • Danny mc
    Danny mc Posts: 24
    edited July 2013
    Thanks I just got the Polk fx surround and my speaker is behind couch and one wall is 4 ft away and other is 14 feet and the Polk chart measurements came up to 35 feet for left surround which manually only goes to 30 on receiver but if I locate my mic and do auto setup then I can tweek it.
  • skrol
    skrol Posts: 3,460
    edited July 2013
    What went bad on the mic? Is it just a broken wire, connector? Could possibly fix it.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • ntculenuff
    ntculenuff Posts: 1,146
    edited July 2013
    I found this for you Setup Microphone
    I was looking because I wanted to see what it looked like. I have a few microphones in my bag of tricks. I am pretty sure i have an extra pioneer mic that will work. I might be able to work something out with you if you want. Let me know.
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • Danny mc
    Danny mc Posts: 24
    edited July 2013
    Actually I misplaced it and looking for it now! Thanks and hard to believe it cost 80 bucks to replace!
  • RamZet
    RamZet Posts: 792
    edited July 2013
    I was able to use a audyssey on my pioneer and a pioneer mcacc on a marantz. I think the setup is just looking for a mic.
    B&W CM9Classé Sigma
  • Danny mc
    Danny mc Posts: 24
    edited July 2013
    Thanks I wondered if mics were interchangeable...Pioneer wants 80 bucks!! That's steep!!
