Setup for my truck, DB6501, DB651, DB351
2StepsAhead
I have a Kenwood DNX6990HD head unit, I am planning to add two Polk DB6501's in the front doors, a DB351 for the center channel and two DB651's in the rear doors for the rear fill. Now my question is do I need an amp? I bought the head unit figuring it would help power a set of aftermarket speakers, not sure if I really 'need' more power. If so how many channels/power would I need? Not sure if I would run some type of bridged setup or if I would need a channel for each group of speakers.
Post edited by 2StepsAhead on
2StepsAhead wrote: »I have a Kenwood DNX6990HD head unit, I am planning to add two Polk DB6501's in the front doors, a DB351 for the center channel and two DB651's in the rear doors for the rear fill. Now my question is do I need an amp? I bought the head unit figuring it would help power a set of aftermarket speakers, not sure if I really 'need' more power. If so how many channels/power would I need? Not sure if I would run some type of bridged setup or if I would need a channel for each group of speakers.
had a similar setup, db6501 and db651 on my truck, definelly need an external amp. the headunit will make them sound better than stock soeakers but no close to their potentialHT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES -
Ok so now my question is how do I get all 5 speakers amped? Do I need 5 channels? Can I run the front DB351 and DB6501's off one channel and then the back DB651's off another channel? I was thinking of grabbing an old Alpine PDX-5 so I can also power a new sub (just looking for a small 8in to replace the factory 8in JBL since it sounds shot after 100,000 miles) but wasnt sure how many channels I would really need.
2StepsAhead wrote: »Ok so now my question is how do I get all 5 speakers amped? Do I need 5 channels? Can I run the front DB351 and DB6501's off one channel and then the back DB651's off another channel? I was thinking of grabbing an old Alpine PDX-5 so I can also power a new sub (just looking for a small 8in to replace the factory 8in JBL since it sounds shot after 100,000 miles) but wasnt sure how many channels I would really need.
i would leave the center channel out of the equation then with a five channel amp power the four speakers and sub. trust me you will not miss the center channelHT:
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
Get a 4 channel amp. Put the front speakers on the front channel, bridge the back for a sub - don't get a center channel
-CodyMusic is like candy, you have to get rid of the rappers to enjoy it
