@ Channel Rack em Stack em
Mikey081057
Mikey081057 Posts: 7,127
edited June 2013 in 2 Channel Audio
Todays Project.
Added a shelf above CDP for TT and Phono Pre. Everthing has its challenges but everthing is isolated and solid. I should have went with this VTI stuff from the beginning and may eventually do that, but for now I have solid functionality and won't be adding any more 2 channel components.
Pics
Garage | Polk Monitor 5B's
Post edited by Mikey081057 on
  • BlueFox
    BlueFox Posts: 15,250
    edited June 2013
    Very nice, and clean. Do the guitar strings vibrate when you play at high levels?
  • Mikey081057
    edited June 2013
    BlueFox wrote: »
    I would imagine in theory they would, but i cannot hear or feel them. The acoustic instruments would be most prone to resonance I would think.
    I have had many listening sessions where I have hit 110 db and above... my head rattles but thats about it. This is a hardwood floor on a concrete slab in this room and I can jump on it with the TT playing with no ill effects.
  • Dawgfish
    Dawgfish Posts: 2,554
    edited June 2013
    Very nice! That's one sweet looking set-up. Bet it sounds great also!
    I'm not trying to rain on your parade or be an a** but do you have any concerns with vibration with your sub being mounted directly under your equipment the way it is? It looks great but I would be concerned about vibration from the sub possibly causing adverse affects on the equipment above it. Just a suggestion to something that may not even be an issue, but could potentially result in better sound if you moved the sub away. Going to hide in my cave now......
  • Mikey081057
    edited June 2013
    Dawgfish wrote: »
    So the sub is not :on the rack, but between the rack isolated by a subdude and spikes. The sub firiing makes no connection to the rack at all.. Really no diifference than having it along side. I don't really crank the sub so that it could move and make any contact with the rack.
  • Dawgfish
    edited June 2013
    OK cool. It was hard to see from the photos. That is one fine looking system you have there!
  • naturallight
    naturallight Posts: 689
    edited June 2013
    OK..thats really over the top...that you have show your 2 LP's and Strats..on top of the fact you have a nice system...thats really over the edge there.....
  • Mikey081057
    edited June 2013
    The burst strat is actually a Fernandes... But the Black One is a '76 Fender that I bought new back when I was a pup in '76. Still my fav of all time.
  • naturallight
    edited June 2013
    Thats right...just rub more salt in the wound....LOL
  • naturallight
    edited June 2013
    Now uless you can make those guitars sound like this....not so sure there worth the money. They look real nice sitting there, but unless you can play them...not so much.....
    http://youtu.be/-VS5g8Fq2rw
  • Mikey081057
    edited June 2013
    He is da man for sure... Don't get to practice much these days... Now more of a collector/hoarder..Guitars are like fine wine to me.
