what version SDA SRS are these? what is a fair price?
telemetry
telemetry Posts: 12
edited July 2013 in Vintage Speakers
Post edited by telemetry on
  • Schurkey
    Schurkey Posts: 2,122
    edited June 2013
    Not original SRS, crossover has fewer fasteners (9 vs. 13) OR the crossover has been replaced (but why?)
    Has black tweeters, if they're original, they're SL3000, so 1.2TL. Otherwise, either 1.2 or 1.2TL, and RD0 tweeters.
    I suppose $1400--$1800 depending on whether the tweeters are originals, somewhat higher if mods are already performed, etc.
  • DaveHo
    DaveHo Posts: 3,583
    edited June 2013
    Those are 1.2 TL's. The foam ring on the tweeters indicates they are SL3000's.
    Toolfan66 Posts: 18,183
    edited June 2013
    They are 1.2tl's, and it looks like some of the drivers have been replaced as well with the newer ones..
    I paid $500 for mine, but that was luck on my side..
  • DaveHo
    DaveHo Posts: 3,583
    edited June 2013
    Good eye. The 2 upper left mid-woofers are replacements. You can tell because the voice coil leads don't peek out from under the dust cap. Also looks like the person who installed them didn't trim the rubber around the screw holes. A couple spots look like the surround is slightly rippled from tightening the screws.
  • JPeixe
    JPeixe Posts: 26
    edited July 2013
    how much would be a fair price for an original and excelent condition pair of SDA SRS? and the price would be higher or lower in europe? cuz i cant find much of this speakers in europe, all speakers i find on the internet are in US
    SDA-SRS
  • PolkieMan
    PolkieMan Posts: 2,446
    edited July 2013
    The big guys SDA SRS 1.2 TLS are the best ones, those in excellent condition are about $1200.
    The older model SDA SRS in the same condition about $900.
    But it's like everything else, where is it, has it been recapped, do you want it now?
  • PolkieMan
    edited July 2013
    I'd say, was there a rainbow that day?:razz:
    Toolfan66 wrote: »
