what version SDA SRS are these? what is a fair price?
telemetry
Post edited by telemetry on
Not original SRS, crossover has fewer fasteners (9 vs. 13) OR the crossover has been replaced (but why?)
Has black tweeters, if they're original, they're SL3000, so 1.2TL. Otherwise, either 1.2 or 1.2TL, and RD0 tweeters.
I suppose $1400--$1800 depending on whether the tweeters are originals, somewhat higher if mods are already performed, etc. -
Those are 1.2 TL's. The foam ring on the tweeters indicates they are SL3000's.
They are 1.2tl's, and it looks like some of the drivers have been replaced as well with the newer ones..
I paid $500 for mine, but that was luck on my side..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
Good eye. The 2 upper left mid-woofers are replacements. You can tell because the voice coil leads don't peek out from under the dust cap. Also looks like the person who installed them didn't trim the rubber around the screw holes. A couple spots look like the surround is slightly rippled from tightening the screws.
how much would be a fair price for an original and excelent condition pair of SDA SRS? and the price would be higher or lower in europe? cuz i cant find much of this speakers in europe, all speakers i find on the internet are in USSDA-SRS
The big guys SDA SRS 1.2 TLS are the best ones, those in excellent condition are about $1200.
The older model SDA SRS in the same condition about $900.
But it's like everything else, where is it, has it been recapped, do you want it now?POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
I'd say, was there a rainbow that day?:razz:They are 1.2tl's, and it looks like some of the drivers have been replaced as well with the newer ones..
I paid $500 for mine, but that was luck on my side..POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
