Basic HTPC set up question
CinderLyon
I finally figured out that my PC graphics card does not support DTS / HD (gfx 570). So after 5 hours of research i notice in an article that someone mentioned getting a laptop for HT. Well, it dawns on me that I have a laptop (gfx 555) and guess what, it is supposed to be able to bitstream, so i plug it into my AVR and set the PC sound to 7.1 channels (in the sound options), and 192k sampling. And presto, my AVR now says that I am in dts HD mstr. Woopie!
However, when i check the info it says the same but it has a sampling rate of only 48kHz and set to 7.1 I was expecting 192kHz. I am playing the blue ray version of the Hobbit using cyberlink 9.6, with cyberlink set to HD pass through on audio (3rd option down).
What am i missing here? i think cyberlink 9.6 might not support 7.1, could that be the issue? going to try a 5.1 configuration and see if that helps.
Fronts: Polk RTiA9
Center: Polk CSiA4
Sides: Polk F/XiA6
Rears: Polk RtiA3
Sub:Polk DSWPRO 660wi
extras: 2x JBL Monitor 4206
AVR: Marantz Cinema 50
Amp: Hypex UcD400 Class D, 2 Channels
Power Conditioner: Belkin PureAV Home Theater Power Console pf60
Many different streamers, Heos, firestick, apple
Center: Polk CSiA4
Sides: Polk F/XiA6
Rears: Polk RtiA3
Post edited by CinderLyon on
The PC laptop graphics card is a GT 555M not gfx 555Fronts: Polk RTiA9
Center: Polk CSiA4
Sides: Polk F/XiA6
Rears: Polk RtiA3
Many different streamers, Heos, firestick, apple -
It turns out that 48khz is the correct sampling rate for blue ray, so all is well.Fronts: Polk RTiA9
Center: Polk CSiA4
Sides: Polk F/XiA6
Rears: Polk RtiA3
