Bi wire help
Jhayman
Jhayman Posts: 1,548
Just got my MIT TERMINATOR 2 bi wire cables from George, I've never bi wired before is it each set of ends to each full terminal or am I going one on top of the other, the complete opposite of normal 2 wire..
My speaker posts are side by side with jumpers connected..
J J
Does itvmattervif the blue side is on top going to tweeters or does it need to go low?
    F1nut Posts: 51,864
    edited June 2013
    Remove the jumpers. One set of leads are marked high output, they go to the top posts. Red is +, blue is -. The other set of leads are marked low output, they go to the bottom posts. Red is +, blue is -.
  • Jhayman
    edited June 2013
    Thank You vey kindly..:razz:
