Bi wire help
Just got my MIT TERMINATOR 2 bi wire cables from George, I've never bi wired before is it each set of ends to each full terminal or am I going one on top of the other, the complete opposite of normal 2 wire..
My speaker posts are side by side with jumpers connected..
J J
Does itvmattervif the blue side is on top going to tweeters or does it need to go low?
J J
Remove the jumpers. One set of leads are marked high output, they go to the top posts. Red is +, blue is -. The other set of leads are marked low output, they go to the bottom posts. Red is +, blue is -.Political Correctness'.........defined
President of Club Polk -
Thank You vey kindly..:razz:ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables
