A9 amp/preamp question
CinderLyon
CinderLyon Posts: 108
I just ordered and have not received yet pair of A9's. I was planning on running my left and right channels of an Onkyo TX-NR515 7.2-Channel Network A/V Receiver to a 555 adcom amp. I just read something about using a receiver that has preamps out. I am pretty sure my reciver does not. Will this be a problem?
Fronts: Polk RTiA9
Center: Polk CSiA4
Sides: Polk F/XiA6
Rears: Polk RtiA3
Sub:Polk DSWPRO 660wi
extras: 2x JBL Monitor 4206
AVR: Marantz Cinema 50
Amp: Hypex UcD400 Class D, 2 Channels
Power Conditioner: Belkin PureAV Home Theater Power Console pf60
Many different streamers, Heos, firestick, apple
Post edited by CinderLyon on
  • CinderLyon
    edited June 2013
    i found a zone 2 option that treats the 515 as a preamp basically. Not exactly what I had in mind. I still would like to know what happens if I connect the 555 directly to the amp? I have 10 more days still to return this amp. So another question is what would be a a good recommend (under $1000 and hopefully lower) receiver to use with the A9's?
    Fronts: Polk RTiA9
    Center: Polk CSiA4
    Sides: Polk F/XiA6
    Rears: Polk RtiA3
  • zane77
    zane77 Posts: 1,696
    edited June 2013
    If you would like to stay with Onkyo, look at the 8xx series for an AVR with pre-outs. Check accessories4less.com for a returned unit for a great price. Just check around for a unit from Pioneer, Harmon, Yamaha, maranta or any of the usual manufacturers.
    Two Channel
    tonyb Posts: 33,072
    edited June 2013
    You can't connect an amp to a receiver without the preouts, if your receiver doesn't have any then buy one that does. Many to choose from, new/used.
  • rpf65
    rpf65 Posts: 2,127
    edited June 2013
    The Pioneer SC 1522k will fit your needs.
  • CinderLyon
    edited June 2013
    I bought a Onkyo TX-NR809 after double checking that it does have preouts. Thanks for the help guys.
    Fronts: Polk RTiA9
    Center: Polk CSiA4
    Sides: Polk F/XiA6
    Rears: Polk RtiA3
  • silverado-j
    silverado-j Posts: 1
    edited June 2013
    Thinking of getting a pair of these and running off of 2 audiosource amp 310's in bridge mode, do they need this kind of power to operate well at high volume levels?
    tonyb Posts: 33,072
    edited June 2013
    Bridged mode at higher volumes probably isn't going to sound too good with those amps. Buy a real 2 channel amp from Adcom, B&k, Parasound, etc. For around 400 bucks used.
