A9 amp/preamp question
CinderLyon
CinderLyon Posts: 108
I just ordered and have not received yet pair of A9's. I was planning on running my left and right channels of an Onkyo TX-NR515 7.2-Channel Network A/V Receiver to a 555 adcom amp. I just read something about using a receiver that has preamps out. I am pretty sure my reciver does not. Will this be a problem?
Fronts: Polk RTiA9
Center: Polk CSiA4
Sides: Polk F/XiA6
Rears: Polk RtiA3
Sub:Polk DSWPRO 660wi
extras: 2x JBL Monitor 4206
AVR: Marantz Cinema 50
Amp: Hypex UcD400 Class D, 2 Channels
Power Conditioner: Belkin PureAV Home Theater Power Console pf60
Many different streamers, Heos, firestick, apple
Post edited by CinderLyon on
  • CinderLyon
    edited June 2013
    i found a zone 2 option that treats the 515 as a preamp basically. Not exactly what I had in mind. I still would like to know what happens if I connect the 555 directly to the amp? I have 10 more days still to return this amp. So another question is what would be a a good recommend (under $1000 and hopefully lower) receiver to use with the A9's?
    Fronts: Polk RTiA9
    Center: Polk CSiA4
    Sides: Polk F/XiA6
    Rears: Polk RtiA3
  • zane77
    zane77 Posts: 1,696
    edited June 2013
    If you would like to stay with Onkyo, look at the 8xx series for an AVR with pre-outs. Check accessories4less.com for a returned unit for a great price. Just check around for a unit from Pioneer, Harmon, Yamaha, maranta or any of the usual manufacturers.
    Two Channel
    edited June 2013
    You can't connect an amp to a receiver without the preouts, if your receiver doesn't have any then buy one that does. Many to choose from, new/used.
  • rpf65
    rpf65 Posts: 2,127
    edited June 2013
    The Pioneer SC 1522k will fit your needs.
  • CinderLyon
    edited June 2013
    I bought a Onkyo TX-NR809 after double checking that it does have preouts. Thanks for the help guys.
    Fronts: Polk RTiA9
    Center: Polk CSiA4
    Sides: Polk F/XiA6
    Rears: Polk RtiA3
  • silverado-j
    silverado-j Posts: 1
    edited June 2013
    Thinking of getting a pair of these and running off of 2 audiosource amp 310's in bridge mode, do they need this kind of power to operate well at high volume levels?
    edited June 2013
    Bridged mode at higher volumes probably isn't going to sound too good with those amps. Buy a real 2 channel amp from Adcom, B&k, Parasound, etc. For around 400 bucks used.
