Pioneer Elite VSX vs SC models
danger boy
danger boy Posts: 15,722
edited June 2013 in Electronics
Never owned a Pioneer Elite receiver.. but i like the new models out right now.. so I'm looking for one. so what's the
difference between the VSX and the SC line?
PolkFest 2012, who's going>?
Post edited by danger boy on
  • jon s
    jon s Posts: 905
    edited June 2013
    The SC line is their top line models. If you interested, you might want to wait for their new models this summer. their unannounced top three models will be using the ESS Ultra DACs. They are the same DACs used by the Oppo BDP-83SE which is known as an excellent audiophile player.
  • danger boy
    edited June 2013
    oh the SC models of Pioneer Elite receivers are out of my price range.. as cool as they appear to be after reading the press release... i think the VSX Elite's fit my budget better. :smile:
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited June 2013
    danger boy wrote: »
    Buy a used sc05 !!
  • B Run
    B Run Posts: 1,888
    edited June 2013
    Buy a used sc05 !!
    +1 I agree
  • jumpindick
    jumpindick Posts: 428
    edited June 2013
    sc series is great for HT. I used to have marantz and when I hooked up sc elite. the difference is night and day. Can't comment on vsx series since I have not used it.
  • mantis
    mantis Posts: 17,325
    edited June 2013
    The VSX series is class A-B amp design. The SC use Class D amps. The older models have B&O Modules , the 5 series and up are all built by Pioneer now called D3.
    SC are the top of the line models. VSX series even entry level models all sound awesome. The SC will get you closer to a Pre / Amp sound then the VSX will.
    What is your budget? Used is probably going to be the best option if you can't afford a new SC. They do however have very affordable models now in the SC range.
    Dan
  • WLDock
    WLDock Posts: 3,073
    edited June 2013
    Decent prices can be found on used SC models on craigslist, ebay, and audiogon, etc. If you want the most for you money, $400-$600 on a used unit will get you a lot of performance. OTOH, I've seen used VSX-92THX model for $300! Again...a lot of performance for the money. New units are ALWAYS great but if you are poor like me, there is so much value in finding a good used unit.I almost picked up an SC-25 for $450 shipped from a guy on CL. However, I am moving and my dedicated HT room is no more. My new space is smaller....but I still plan to pick up an SC at some point.
  • danger boy
    edited June 2013
    welp.. i couldn't resist getting a new receiver so i opted for the new this year model Pioneer Elite VSX-70 lots of bells and whistles..
    i to need to downsize the home theater. I honestly don't use the HT much anymore. so it was time to upgrade and the price of the
    VSX-70 fit my budget. My friend has last years model a step or two down.. VSX-42 I think and it sound quite good to me.
    perhaps, next time i'll go with an SC model.. ;)
