Trying to install a new stereo in a tractor,, what wire goes where?
polkfarmboy
polkfarmboy Posts: 5,703
Hi guys this is a time I need help most
I am trying to install a stereo but I need to figure out what each wire means by color thats hanging from the roof of the john deer
I have red, green, blue purple, white and brown and black
Once I figure this out I can hook it up to the diagram thats on the back of the stereo
Post edited by polkfarmboy on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2013
    Got a meter? If not I'm lost also. Find continuity between 2 set of wires they must be the speakers I would think BLue / BLue and the Black / Black But not a lot of wiring there? Maybe the speakers are ground so be cafeful most radio will blow up if that is the wired that way.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • decal
    decal Posts: 3,205
    edited June 2013
    DSkip wrote: »
    Bye bye tractor.
  • zane77
    zane77 Posts: 1,696
    edited June 2013
    I thought I was the only one that had to have a CD player in my tractor. Not sure what the colors are for but your local JD dealer would help you out I am sure.
    Two Channel
  • disneyjoe7
    edited June 2013
    A test light maybe nice to check power wires also.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited June 2013
    PM me your model, year and serial number as there are often running changes. I may be able to look it up in the technical manual if your Operator's manual does not have it. Don't post the serial number on this site. Most are industry standard pinouts.
  • Polkersince85
    edited June 2013
    zane77 wrote: »
  • WLDock
    WLDock Posts: 3,073
    edited June 2013
  • ken brydson
    ken brydson Posts: 9,015
    edited June 2013
    This could go so wrong....
  • polkfarmboy
    edited June 2013
    Well I did try just putting the cd player onto the battery and that powers up, I am thinking I might have a bad ground connection now that I figured out what the power is and the speaker wires are
  • zane77
    zane77 Posts: 1,696
    edited June 2013
    Polkersince85, That is a sick tractor. Mine is a little older Case/IH with a cab that is used mainly for snow removal and mowing the pasture with a brush hog. Up here you definately want one with a cab for heat and air.
    Two Channel
  • zingo
    zingo Posts: 11,258
    edited June 2013
    The dealer should have a wiring diagram.
  • dromunds
    dromunds Posts: 10,136
    edited June 2013
    We had a radio mounted on the fender of our '67 JD 2510 right from the dealer. Can you imagine playing the radio on an open platform tractor above the noise generated by baling hay or plowing? You had to play it so loud you could hear it in the next township. You can also imagine it was not used much before being taken off the fender leaving a couple big holes.
