Ed's PB2-Ultra review is up on HTF
jdhdiggs
jdhdiggs Posts: 4,305
Just an FYI for all interested party's, oh, and Sid, he stacked the LSi's on the RT800i's...
And Doc, well done....!
There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
Post edited by jdhdiggs on
  • faster100
    faster100 Posts: 6,124
    edited June 2004
    wow, what a heck of a review... will have to check that out when i have more time... That's a long one.. how long did that take to write out?
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • dave shepard
    dave shepard Posts: 1,334
    edited June 2004
    I sure don't know where he finds the time. Reading that I think I have to start saving my money if there is a big diff, between the 2+ and the ultra that can justify the cost. Cant wait for his review on the B4 when he gets one of those :D hell maybe the B4 will get the ultra drivers to give it that much more, now that would make even the most bass hardened listener feel satisfied. Reading things like that just gets my gears moving.
    Dave
  • pjdami
    pjdami Posts: 1,894
    edited June 2004
    Damn. Doc even brought the sub outside on a pallet to do ground plane testing. That is one heck of a long interconnect / power wire. I thought to myself "he can't be serious" when he told me once to try that out. I guess he was serious afterall.
    Kudos Doc. You have outdone your last review again.... as hard as that is to imagine.
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited June 2004
    Thanks, guys. That was a fun project. Yeah, it took forever, but you pick away at it and it's not too bad.
    Ground plane is better for really powerful subwoofers like the PB2-Ultra. Inside, they rattle the entire house and create false positives on the distortion spectra display.
    And it's hard to get a decent nearfield FR curve because the box is so big and the drivers and vents are too far apart to get decent summing at 1 meter.
    2 meters GP is the gold standard. I just wish I had better weather so I could GP all year round.
    SVS
  • jdhdiggs
    edited June 2004
    Now, how did the 7's blend for two channel? Was that in your review and I spaced it?
  • dorokusai
    dorokusai Posts: 25,638
    edited June 2004
    Excellent review, as usual. I wouldn't expect anything less from Dr. SVS...I mean Spec ;)
  • Dr. Spec
    edited June 2004
    Ha! No where else to put them for the present. They are a bit high for optimum, but still sound really good.
    The 7's have remarkably good bass response into the 60's, which is perfect for an 80 Hz xo to a sub.
    I didn't discuss the 7's per se in the review. I did discuss how difficult it can be to get a smooth transition from the speakers to the sub.
    You can see how ragged the transition bandwidth was before I optimized the phase, low pass, and PEQ on the SVS. Worked out really well actually.
    The only thing I did differently so far with the 7's is disable the low pass on the SVS. I haven't spent a ton of time looking at the crossover between the 7's and the SVS yet.
    SVS
  • jdhdiggs
    edited June 2004
    My 7's are atop my 800's as well... I didn't think the 7's would have much of an issue blending, but just wanted to be sure...
  • Dr. Spec
    edited June 2004
    Not only do they blend well with the SVS, they also blend well (surprisingly) with the CS400i across the front stage.
    I thought the timbre match would have been poor, but it's not.
    SVS
  • faster100
    edited June 2004
    when i tried my 7's on top of the 70's unhooked of course, i calibrated them and it seemed by time the 7's were loud enough the svs was way to loud, maybe i did something wrong...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Dr. Spec
    edited June 2004
    i calibated them
    I found the LSi7's to be about 2.5 dB lower in sensitivity than the 800's.
    I saved my old settings for the 800, so I can switch back and forth as needed. Right now, I'm leaving the 7's running for both music and HT applications.
    SVS
  • faster100
    edited June 2004
    Ah never took that into consideration, so 2.5 clicks up on the 3803 from what the 70's were set at?
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • jdhdiggs
    edited June 2004
    Other way Faster... Turn the sub down 2.5 clicks...
  • Dr. Spec
    edited June 2004
    I recommend recalibrating the entire system when new speaks are added.
    Dropping the sub level will work for 2 channel, but not for HT, where the other speakers would then be louder than the less efficient 7's.
    It's a good thing to check system calibratrion occasionally, anyway.
    SVS
  • faster100
    edited June 2004
    Thanks for the correction, so what about for HT? are you useing the 7's in HT for now? and if so how do you get them to sound equal to the other speakers... and sub
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • jdhdiggs
    edited June 2004
    You can calibrate each speaker seperately and once set, they should stay set. Some pre's/reciever's will have different settings for multichannel and stereo modes, some don't. But once you have all the speakers calibrated, you should be set for all volumes and formats. This worked when I was using mismatched speakers and also works for the matched pair. You pretty much have to start all your calibrations over again.
  • scottvamp
    scottvamp Posts: 3,277
    edited June 2004
    Dam - got me looking at the PB2+ again. May be putting the PSW1200 on Ebay this week. :D
  • Dr. Spec
    edited June 2004
    Take a close look at the power compression curves for the PB2-Ultra in the 25 Hz tune. 115-120 dB at 2 meters OUTSIDE?!!
    In a typical room, the PB2-Ultra in the 25 Hz tune will not begin to compress until close to 125-130 dB peaks in the 25-30 Hz region. I've hit over 120 dB - at the seat - on Underworld.
    SVS
  • dave shepard
    edited June 2004
    What would the differance be using the 2+? The 2+ shakes my house now as I'm sure it did yours does the Ultra shake it much noticably more at the same volume and settings?
    Dave
  • scottvamp
    edited June 2004
    The Ultra doubles in price - i'm trying to justify the +. ;)
  • Dr. Spec
    edited June 2004
    The PB2+ is right behind the Ultra - subtract about 2 dB across the board. The PB2+ is a better performance value, no doubt.
    SVS
  • faster100
    edited June 2004
    I think the difference at that level is quality of parts moreso then better performance per se'
    you get a better cabinet, better drivers, bit bigger amp...
    but the same overall setup,
    I say the pb2-isd and + are a great value/performance buy
    when you get into it like Ed, its the natural step up to get the Ultra and go all out... he will most likely never 'Need" another sub, But want is a different story... like when i went from pb1 to pb2, I really just wanted the pb2 Bad :)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • scottvamp
    edited June 2004
    NICE!!!!!:D
    That Maple finish is awesome. I will enjoy the black - my home style is much more comtemperory.
    Doc - what did you do with the other SVS? It was a PB2+ right?
  • faster100
    edited June 2004
    Not to answer for him, but he sold it... I think to a member here :)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Dr. Spec
    edited June 2004
    Sold it locally, actually. It's pounding away in a Klipsch Reference 7 system and sounds fabulous.
    SVS
  • gatemplin
    gatemplin Posts: 1,595
    edited June 2004
    Just read the review doc and really enjoyed it, worth the wait. I have learned so much from your posts and reviews.
    Graham
  • Dr. Spec
    edited June 2004
    Thanks! Hey we got your EBS working right....that was worth sumpin' right?
    SVS
  • gatemplin
    edited June 2004
    Yep, it is working great now. Back then it was a under achieving 150L with an 8" port. With your help I decided to build the EBS. Since then I rebuilt it for fun with more attention to details and some slight modifications. I think I will post a FR curve if anyone else is interested in what you can do with a DIY sub.
    Graham
  • Strong Bad
    Strong Bad Posts: 4,278
    edited June 2004
    Doc:
    Hell of a review! I enjoyed it tremendously! The guys at SVS should put you on the payroll!
    It's great to hear how well the 7's blend with the SVS and the CS400. I picked up a pair of 7's recently (the Fry's deal) and plan on using them as the main L&R in my surround setup. This will eventually promote my SRS 2.3's to a 2 channel stereo setup.
    Again, great review!
    John
    No excuses!
