Surroundbar SDA fried circuit board
pjsquared
There is a distinct black burned spot on the main circuit board. I am in Canada and the warranty has expired. Is there a place to get a replacement?
Post edited by pjsquared on
Hello,
Welcome to Polk's forum, I'm sorry there's a problem. It would be best to contact Polk's Canadian manager, Walter Moser at: wmoser@polkaudio.com and you can email Polk's main CS department at: polkcs@polkaudio.com with a telephone number of 1-800-377-7655.
I'm sure they'll be able to help you out.
Regards, Ken -
You keep response times to 5 minutes and Polks' CS rep is gonna be ruined forever!
Amazing, seriously.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
I lucked into that one, I try and check things five or six times a day.
Hello Kenneth,
My RT3000 plate amp has a fried spot on the circuit boaord, the smaller one, NOT the one with the capacitors. Can it be repaired? Sorry, I don't mean to hijack the thread.
Frank.Kenneth Swauger wrote: »Hello,
Regards, KenSRT Seismic System with dual PSW1200's
RT5000 x 2
RT2000p
CS400i
CS350-LS
LS F/X
PSW650
PSW1000 w/Dayton SPA1000
DSW MicroPro 4000
Adcom amps
Pioneer Elite SC-89
Pioneer PLX-1000 Turntable
PS4
XBOX One
MIT Interconnects
BJC -
Hi chef,
It's probably best to begin with Polk CS, see if they have a way to look at the amp, the number is 1-800-377-7655. I'm not sure if you have contacted them already.
Regards, Ken -
2hrs... he's slipping now
2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer. -
Getting old, I guess...
