Items for sell
Terrax
Wanting to sell a few items. I have no interest in offering these on ebay and would like offer these items here to you all.
Marantz 7300OSE Receiver: http://www.marantz.com/hifi/america/main.html 8/10 if not 9/10. $400.00 + shipping / conus
Boston Acoustics HD-8 Bookshelf Speakers circa 1993: These are black with 1" soft dome tweets and 8" mid-bass drivers. 8/10 $85.00 + shipping / conus (Price dropped)
Edit: All items will be double boxed and packed to withstand UPS or Fedex shipping.
Thanks for looking,
-Terry
Thanks for looking,
-Terry
Post edited by Terrax on
Specs for Marantz 7300OSE receiver:
SR7300ose
SUPERCHARGED VERSION OF THE SR7300
The Marantz SR7300ose, a supercharged version of the Marantz SR7300, is designed for exceptional high-end home theater performance that incorporates DTS ES-discrete 6.1-channel decoding for enhanced surround sound realism. The additional back surround channel decoded from DTS-6.1 encoded discs provides a more realistic surround sound environment by allowing smoother, 360-degree sound effects. For enhanced performance, the SR7300ose incorporates a copper plated chassis with double bottom plate, upgraded power supply, better shielding and wiring and gold plated input and output jacks. The Marantz SR7300ose also offers a selection of other useful surround modes, including Dolby Digital EX, DTS 5.1 decoding. Dolby Pro Logic II (Music and Movie) decoding, an HDCD decoder, as well as SRS Circle Surround II (6.1). The SR7300oses advanced DSP circuitry utilizes 24-bit, 192 kHz audio decoding and a leading edge Crystal DSP chip for superlative fidelty and resolution. The SR7300ose is software upgradeable and easily controlled via a RS232C terminal and includes a programmable learning remote control.
FEATURES
110 Watts x 6 (Into 8 Ohms)
All Discrete Amplifier Stages
192 kHz/24-bit D/A Converters For All Channels
Dolby Digital EX 6.1/5.1, DTS 6.1/5.1
DTS 96/24
Dolby Pro Logic II (Movie, Music)
6 Channel Stereo Mode
HDCD Decoder
Multi-room, Multi-source Capability
Speaker A/B Switching
Gold Plated Inputs/Outputs
Copper Plated Chassis With Double Bottom Plate
Several modifications to the Power Supply, Signal Path, Output Devices, Preamp Stage as well as improved internal Wiring and Shielding
SUPERCHARGED VERSION OF THE SR7300 FEATURED
MULTICHANNEL/SURROUND
Software Upgradable (RS-232)
THX
DTS ES 6.1 Discrete/5.1/Neo:6 + DTS 96/24
Dolby Digital EX
Dolby Pro Logic II Yes
Circle Surround SRS CS 6.1
SOUND ENHANCEMENTS
HDCD Decoder
Current Feedback Topology
Discrete Amplification Yes
Power Transformer EI (Upgraded)
D/A Conversion 192 kHz/24-bit (Hand Selected)
Digital Surround Processing Crystal (Hand Selected)
Video Off
Source Direct
Chassis AllCopper w/ Double Bottom Plate
Customized Components
Shielding Extensive Shielding in all Critical Areas
IN/OUTPUTS
VIDEO
Composite In 5 (gold plated)
Composite Out 3 (gold plated)
S- Video In 5 (gold plated)
S- Video Out 3 (gold plated)
Component In 2 (gold plated)
Component Out 1 (gold plated)
AUDIO
Analog In 8 (gold plated)
Analog Out 4 (gold plated)
Digital In 7 Total
Digital Optical In 4 (3 assignable)
Digital Optical Out 1
Digital Coaxial In 3 (assignable)
Digital Coaxial Out 1
OTHER
Pre- Amplifier Out 7.1 Channels (gold plated)
Main Amplifier In
Multi-Channel In 8 Channels (gold plated)
Multi-Room Audio Out L/R Pre-out (fixed or variable)
Multi-Room Video Out 1 (CVBS)
RS232C
DC Triggers 2 (assignable)
Speaker Terminal A/B + C, Sl, Sr, Sb
Multi-Room Speaker Terminal
D-Bus RMC Out Yes
Multi-Room RMC Yes
External IR Yes - thru RC-5
AC Outlets Yes, (1 switched/1 unswitched)
Front Inputs L/R, CVBS, S, Opt. Digital
Headphone Out
SPECIFICATIONS
AUDIO SECTION
Power Output (8 Ohm) 110 W x 6, (<0.08% THD, 20Hz - 20 kHz), SA-Ready
Signal to Noise Greater than 105 dB
Freq. Response (Analog In) 8 Hz - 100 kHz
Freq. Response (Dig In) 8 Hz - 45 kHz
Input Sensitivity 195 mV/47k Ohms
TUNER SECTION FM
Frequency Range 87.5 - 108.0 MHz
S/N Ratio (Mono/Stereo) 70 dB/75 dB
Distortion (Mono/Stereo) 0.3%/0.2%
Channel Selectivity
Usable Sensitivity IHF 1.8µV/16.4 dBf
Channel Separation Greater than 45dB (1 kHz)
TUNER SECTION AM
Frequency Range 531 - 1710 kHz
S/N Ratio 50 dB
Distortion 0.5%(1 kHz)
Channel Selectivity
GENERAL
Color Black
Front Panel Aluminum
Remote Control Learning with LCD - RC7300SR
Power Requirement AC 120v / 60Hz
Dimensions Inch W x H x D 17 5/16 x 6 3/8" 18 1/4"
Weight 35.1 -
Terry is an excellent individual to deal with, negotiate with confidence, he's solid.
He's real cool to chat with voice, and always a lurking presence in the forum
CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
< a voice from the shadows can be heard in the distance >
Thanks doro, coming from an awesome guy such as yourself, it means alot. Thank you. < The Lurker >
Specs for Soundcraftsmen PM-840 Amp:
205 watts/rms @8ohms; 410 watts/rms @4ohms
<.05% THD @ rated output
108dB SN Ratio
20-20kHz Frequency response, +/- 1db
130mv slew rate
No current limiting design
Class D "rail voltage" design that runs very cool
Output for one set of stereo speakers, 5-way binding post
Power switch, LED, and 2 clipping LED's
Original factory (hand written/signed) QC checklist and spec's -
I'll offer you $300 shipped. I can paypal immediately. Why would you rate it a 8/10? Does it work fine, is it scratched up? Do you have the box, manuals & remote? Let me know.
seems like a sweet receiver
Audiogon Ratings ...
9 / 10 - Excellent - Perfect physical condition, light use.
The item should be a one-owner or store-demo piece to qualify for a 9/10, though some exceptions will exist. The item should appear as new unless a very close inspection is performed, as described below.
Electronics should look factory fresh except for dust in crevices. The plating on i/o connectors may show some use, but no discoloration or oxidation. The item should never have been rack mounted. Chrome should have no pitting and no discoloration.
Speakers should be perfect except for the back or bottom, which may show slight indentations from stand mounting, but the indentations do not show through the veneer. Wood finishes should not show any change in color from sunlight, especially uneven discoloration. Grill cloth should have no pulls, but maybe dusty.
Turntables may show slight wear where the cover is lifted, but no visible wear on the top of the cover, or the plinth. The headshell should have no scratches from cartridge mounting.
8 / 10 - Very good - Perfect front face, 1 minor flaw on top or side is acceptable.
This item has seen some use, but still appears perfect from the front. A perfect front face plate includes the front top edge. Be sure and check this edge since it is very easy to nick. On speakers, all four front edges should be inspected.
Electronics may have 1 or 2 minor scratches (max 1/2" long, very thin) on the top plate or the sides of electronics, but again, the front must be perfect. There should be no signs of rack mounting. Chrome should have no pitting, but may have some discoloration in spots less than 1/4" diameter. Silk-screening has no separations, and the lettering shows no wear.
Speakers may have minor discoloration along edges, but no scratches that show through the veneer, except for the bottom, which may show signs of stand mounting or floor scraping.
Turntables covers may be slightly hazy from record sleeves being laid on them, but should not have any highly visible scratches anywhere. The headshell may have some scratches from cartridge mounting.
7 / 10 - Good - 1 or 2 minor scratches, looks used but well maintained.
Electronics should have no dents or bulges, but a few minor scratches. Perhaps a little wear on the knobs and switches, like the slightly darker or shiny coloration seen on volume knobs. If the item was rack mounted, plastic washers should have been used. Chrome may show slight pitting, but not enough to be visible without close inspection. Silk-screening on the glass is separating in at most one area of less than 1/2" diameter, and some parts of some letters may have worn off.
Speakers may have loose fitting covers, or the cloth may have 3-5 minor pulls or 1 small hole less than 1/2" long. The cabinet may have one minor scratch that shows through the veneer, but no bigger than 1" long. The bottoms of speakers may show many small scratches or scrapes
Turntable covers may be hazy, and the tonearm may show heavy scratches from repeated cartridge replacement. . -
Well then, as far a Audiogon ratings go, the Marantz receiver would be a definitive 9/10. Thanks for posting the ratings PW.
I am biting on a $275.00 loss for the receiver as is, with it priced at $400.00 + shipping. $400.00 is, in my belief, more than fair for a receiver of this caliber and condiction. I have only had it like close to 5 months. (And only driven on Sundays, at no more than 35 Miles an hour. - J/K'ing) Give or take. This unit sold for $1100.00 smackers last year, new.
Did u buy the unit used or new? Does it have a warranty?
What are you, Jewish???:D -
I know someone who is interested in the receiver. How much will shipping be to 75035?
The receiver is roughly 35 lbs. ATM, I have no way of checking a shipping charge, as I am at work. I can try and find out though. I do remember shipping a 24 lbs receiver to Az. from 28752 (Marion, N.C.) and that ran like $22.00. -
I'll give you $400 including shipping. Last offer. I can paypal immediately, but I want to know if you bought the receiver used or new. Let me know.
The receiver was purchase from Jimmie, another well respected Polkie, who takes great care with his gear. He purchased it new, only a couple of months before I bought it from him. I have the Manual and remote, which is also in great shape. There is no sign of wear on this unit that I am aware of, in the least. I thank you for your offer, but I really insist on $400 + the shipping charge. Also, I have no way of taking Paypal. And would prefer US Postal Money Order, in this case.
-Terry -
UPS ground from 28752 to 75035 on a 36 lb package would run roughly $23.00, give or take.
-Terry -
no thanks, i only deal with paypal. www.paypal.com it is free to sign up.
OK Terry...
I'll talk to him and see if he can do $425. I'll let you know ASAP.
Thanks -
Okies, Thanks man.
:eek:What are you, Jewish???
That wasn't very cool. You have no idea which members may be Jewish and you could have offended someone.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Originally posted by dragon1952
:eek:
eep!
I would certainly hope this is not taken out of the context in which I'm sure it was (I believe) originally meant. I would think that it was in reference to jewing a price down, not to offend anyone.
But it does go to show, that, even in jest, we have to be mindful of what we say, as to not offend. I'm sure "amulford" meant no harm.
-Terry -
Get a freaking tissue, jesus it was meant in a joking way! If someone is going to get that mad, you might as well lock yourself in a padded room. Man, learn how to interpret comments.
*Update* There was a local pending trade for the Soundcraftsmen amp, but couldn't be worked out. The amp is still for sell.
-Terry -
Friend is back in town tonight...I'll let you know something ASAP.
you know, I was thinking of buying the Marantz for myself and selling him the Denon...hmmmm...
Anyone have any idea of how this Marantz would stack up against the Denon 3801?
I love my Denon, but am always open to other ideas... -
PM,
There are some really good reviews on the 7300OSE on the net, that you can do a search for. I must say, it is a very musical receiver. And I have no faults with it at all, the only reason I'm selling it and the other stuff is to try a fund the purchase of some Planer speakers.
-Terry -
I don't think I went off the deep end here dude. I made a very brief and simple comment....no anger there. Why don't YOU learn to interpret. I know it's meant as a joke. That's the whole freakin' problem, Einstein. It's been used as a joke for a hundred freakin' years, and it's a poor one.
Additionally , there is only one interpretation of that phrase which is derogatory to those who are Jewish. No matter how widely used or how long it's been around it implies that all Jewish people are penny-pinching tight wads. That's how it got started or maybe you're to young to know that.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Exactly, and well said. And, yes, I'm sure he didn't.
BTW, the above rant was only directed at Einstein.
Amp is sold. Receiver and speakers still up for grabs.
Terry -
Hey Terrax can you post a pic of the speakers Im buying my sister a start up rig and I might be interested. And my nose is verry small.;)Wish I was a polkologist then I could call my self Dr.warviper.
