New addition to the HT and concerns
  • xftman
    xftman Posts: 153
    edited June 2013
    Here you go, $169 (even better the lowest so far) after coupon with free shipping and possible no tax depend where you live.
    coupon code: EMCXPXS22
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882290272
    MAIN:
    Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
    Center- lsiM 706,
    Surrounds- lsi F/X,
    Power sub PSW1000,
    Receiver- Harman Kardon Avr 3700,
    Amp - Emo XPR-5.
    Secondary (2.1):
    LsiM 703,
    HK Avr 3700,
    Yaqin MS-30L,
    Polk DSW-PRO 400.
  • custopper30
    custopper30 Posts: 252
    edited June 2013
    So here is the deal... the only thing that I can do is ship the speakers back and they will ship me the same monitor 70s that aren't broken back because they won't refund or discount any other item...
    Receiver: Denon 1912
    Speakers:
    Fronts: Polk Audio Monitor 70s (x2)
    Rears: Polk Audio Monitor 50 (x2)
    Center: Polk Audio Monitor 70
    KLH Sub GFX-550
    EndersShadow Posts: 17,687
    edited June 2013
    That sounds like a very fair deal personally. I dont see them discounting a newer model for you and the site does say no refunds.
    Personally I would see if they can just send you a new cabinet since the ones you've got are the issue not the drivers. Its pretty simple to switch all that stuff out and might be the easiest solution.
  • custopper30
    edited June 2013
    They just said they will just replace the whole speaker.
    Speakers:
    KLH Sub GFX-550
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited June 2013
    Good deal, I bet the next set will be perfect. Polk cares greatly about their customers satisfaction.
