doesn't seem worth while
Manufacturer
Model Polk Audio PSW202 10" and Subwoofer Velodyne CHT-10 10"
Price $349.99 $449.99
Power Capability 100 Watts (polk)375 Watts(vel)
Amplifier Power 100 Watts(polk) 375 Watts/150 RMS(vel)
Frequency Response 30 Hz - 180 Hz (polk) 28Hz - 120Hz (vel)
they have one as open box but it hardly seems worth while does it ?? am I missing something ???
Post edited by Willow on
What doesn't seem worthwhile?
Don't use specs alone when looking at gear, you have to listen.Political Correctness'.........defined
President of Club Polk -
I'm not sure what you're getting at....but if they're trying to charge $349 for a 202 then it's definitely NOT worthwhile...
That's loony Canadian funds.
SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop. -
the prices are CAD thats why they might seem high..I have a 202 but my wife saw the velodyne cht10 open box....I don't know if its better to go with the cht or keep the 202 and down the line buy a svs or hsu.... if I dont get the cht maybe upgarding the mains rti4 to rti6 might be a better upgrade than the sub
Maybe a correction to the PSW202 specs would help your decision. Here's the correct range:
Overall Frequency Response 40 - 200Hz
Lower -3dB Limit 45
Upper -3dB Limit 180
Crossover Variable 80 - 200Hz
Inputs Speaker level and line level
Outputs Speaker level pass-through
40hz - 200hzHome:
Denon AVR-1803
Polk CSi30
Polk RTi70
Polk RTi28
Polk PSW-303
Car:
Kenwood KDC-BT945U
RF Punch P400-4
Polk MM6501
Polk MM651
RF Punch P300-1
Boston Acoustics G312-4 -
damn futurshop website they can never keep the specs straight!!
well the diff between 28 and 40 is a big gap.....hmmm maybe it is worth it.... -
the cht 10 is in the same league as the psw 404. You can't compare the 202 to it, and yeah, it probably is a worthwhile upgrade if you're unsatisfied with your bass, and I think you'll probably notice a bigger difference then upgrading your rti 4's to rti 6's, but that's just one man's opinion.
its not that Im not satisfied I know Im missing out on how low the bass can go...hmmm stuck now..what to upgrade first....fronts or sub
If I go the main route wont the csi3 seem a tad whimpy with the rti6s?? -
Not at all...Originally posted by Willow
why not just hold on to your money for a bit and upgrade to a HSU or SVS? -
guess the upgrade bug is itchin real bad...maybe keep as is and getter a much better sub a bit later...shoot
See I'd replace my r10's in rear with the 4's and 6's up front , the r10s are good but not up to par with the rest of the system -
Then your speakers will be voice matched and all grills will match being from the rti/csi lines.
I have the rti6's with the csi3 in the center and fxi3's in the rear and the sound stage is great. -
maybe I should just look at some fxi3's for the back and keep my 4's for now
I've found that if you just hang onto your cash for a little while you usually end up finding a better deal.... Like I was almost going to buy a pair of rti6's for 500 cdn (before tax) but I held off.... Week after that I had a pair of lsi7's coming my way for somwhere between 400 and 500 cdn. Just and idea.
i think the fxi3's are awesome! The rti6's should add a little something to the front sound stage over the 4's though.
Tough choice. I say get the fxi3 (greater improvement over current rears IMO), then tell your wife you want the 6's for fathers day. If you don't have kids, nows a good time. If you don't have a wife, back to a tough choice. -
I think thats what Im going to do I was just wondering what would be the best upgrade to do first incase I see a or many deal(s)
The Velodyne isn't a bad sub at all. I had the CHT-8, and I thought it was a definite improvement over the 202. I've only listened to the 10 at Circuit City, and I thought it did an admirable job with movies. It's much, much better than the 202, and it's right up there with the PSW404.
