Pio SC-05 will it drive LSi's?
EndersShadow
EndersShadow Posts: 17,722
edited May 2013 in Electronics
I know its not "listed" as being able to drive 4 ohm loads, but IIRC mantis ran some 4 ohm speakers off either the SC-05 or SC-07. To you LSi owners would you run your LSi setup off the SC-05 or not? Looking at the one in the misc deals if its still around but ONLY want to get it if I can then sell my Carver 5 channel (to re-coup the cost and simply my setup).
Thanks in advance.
Post edited by EndersShadow on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2013
    Yes, I've ran some lsi 9's and 7's off my sc-07. I'd add a amp later down the road. Did he respond yet?
    edited May 2013
    leroyjr1 wrote: »
    Not yet. Well I would prefer to not have to add an amp, especially since I have one now and would more than likely sell it to come up with the funds... I would eventually be running my LSi 15's off their own amp so it would just need to handle the LSiC and F/X's for now (with another set of 7's as surrounds maybe in the future)
    If I would have to have a dedicated amp channel per speaker then I might just pass for now. I want to try to get things as simplified as I can with my next AVR purchase (hence liking the SC 65 and SC 67, but they are MUCH MORE than 300)
    edited May 2013
    Can you......and should you are two different things. For the LSI 15's to sound their best, then you should have an amp on them. If simple is the goal, the A7's and that receiver with a good sub would keep anyone happy for a long time.
  • hertz9753
    hertz9753 Posts: 310
    edited May 2013
    I started with 2 LSi9's and a H/K 3490 reciever. It was not enough power. Bought an Adcom GFA-5400 amp and used the H/K 3490as a pre-amp. Still not enough power. I am happy with my HT for now...Time to get back in my hole. :neutral:
    AVR-Onkyo TX-NR808
    Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
    Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
    Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
    Sub-Velodyne SPL-1000R
    edited May 2013
    tonyb wrote: »
    The 15's would have a Carver M1.0t on them eventually (it needs some work done on it currently) so they wouldnt be driven off of it so it would be just the sides and surrounds off this amp.
  • erniejade
    erniejade Posts: 6,321
    edited May 2013
    Are you going to use it in 5 or 7 ch? if only in 5, you can take the back 2 channels and biamp the lsi
    edited May 2013
    erniejade wrote: »
    Well its kinda a moot point as the unit in question currently is going to Pitdogg2 unless he passes and if its a legit deal then he wont lol. Should he pass on it I will be all over this baby.
    Eventually I will get me a Pio SC model in the next year or so (I can be patient), but more than likely it will be one of the newer models as unless a steal of a deal comes along I would like to get one with the options of heights or wides so a 9.1 setup or 9.2. Either way I will more than likely keep the Carver M1.0t on my LSi 15's as their simply is no substitute for 500 wpc for each speaker no matter how many channels of the SC you hook up to it lol.
  • leroyjr1
    edited May 2013
    I'll be traveling thru Indy and down to Orlando stopping in Knoxville and Atlanta. If you see anything along that route let me know and I'll pick it up for you.
    edited May 2013
    leroyjr1 wrote: »
    Will do! Thanks!
