Need HELP subwoofer has loud HUM
I just got a modded PSW1000 today and as soon as I hooked it up I get this loud Constant hum coming from the sub. I contacted the seller and he said its a ground loop issue and that I should get a power conditioner to fix it. I looked online and someone Saids to get a directional subwoofer cable. I have tried switching outlets but no luck. The only time it stopped is when I took it into another room and hooked it up to a different setup. I also have 2 amps connected to the same SurgeX protector in the main HT. this was not happening with my PSW505 if anyone has a solution please reply. Thanks
F:L/R LSi 15
Cen: LSiC
Sur: LSi FX
SurBack: LSi 9's
Sub: Modded PSW1000
Sony STR-DA4400ES
Emotiva UPA-200 W/Black Trim
Emotiva XPA-3 W/Black Trim
Samsung PN58A650 Plasma
Plasma TV Wall Unit SKU: SH-CAESAR-WU
Post edited by nme medic on
    pitdogg2 Posts: 26,931
    edited May 2013
    nme medic wrote: »
    maybe ground loop but to me it sounds like power supply filter cap is bad....
  • zane77
    zane77 Posts: 1,696
    edited May 2013
    If the filter cap was bad it would hum on the other system also
    Two Channel
  • Speedskater
    Speedskater Posts: 495
    edited May 2013
    Standard trouble shooting procedure:
    Start from scratch, unplug everything, AC, interconnects, TV set-top box, computer, power conditioner.
    a] Plug the sub's AC into the wall, does it hum? (if not)
    b] Plug the receiver into the same AC outlet, use a plan-jane interconnect from receiver to sub, does it hum? (if not)
    c] Continue adding one component at a time, all into the same outlet, always using plan-jane interconnects.
    Some common sources of hum:
    Telephone cables
    Internet cables
    Satellite or Cable TV cables
    PC's
    Game boxes
    Connecting some of your components to one AC circuit and the rest to another circuit.
  • zane77
    zane77 Posts: 1,696
    edited May 2013
    Great guide Speedskater
    Two Channel
  • chris23120
    chris23120 Posts: 95
    edited May 2013
    nme medic wrote: »
    Glad to see your putting the forum to good use.. this is what I first suggested. Its costs about a buck at Lowes..
    but I also suggested getting a nice power conditioner considering the level of equipment that you have gathered. Many of us on the forum have learned that lesson the hard way. Its money well spent and there are several different units available, most of which will add aesthetically to your AV rack. If you are convinced the amp is at fault, its under warranty and I am a distributor for Dayton so no worries. If your still not happy your unit is covered by the EBAY 2 week return policy, and I have a list of people looking for these so I have no issues taking it back, since they are sold out now. I would definitely try the cheater plug first.
    Samsung UN55C6500 55" LED
    Onkyo TX-NR3007
    Polk Audio RT5000
    -RT3000 front
    -CS1000 center
    -FX1000 dipole
    Polk Audio PSW1000 5.1 sub
    Polk Audio microPRO 4000 x2 5.2 subs:biggrin:
  • nme medic
    nme medic Posts: 98
    edited May 2013
    Thanks for all the help! Since my original post all I have been doing is trouble shooting. I found the problem it was my cable TV line. As soon as I unplugged it the hum was gone. I'm glad I found it because I was starting to get really pissed off. Hahahaha. I am doing a big move soon so I'm not going to bother calling the cable company but I did run over to a local store and picked up a cable TV ground loop isolator. I do plan on getting a conditioner but can't right now because I just spent a few hundred on a new amp and the modded PSW1000. Again thanks for the quick reply
    F:L/R LSi 15
    Cen: LSiC
    Sur: LSi FX
    SurBack: LSi 9's
    Sub: Modded PSW1000
    Sony STR-DA4400ES
  • nme medic
    nme medic Posts: 98
    edited May 2013
    chris23120
    NO way am I sending this back:cheesygrin: I love it! And now that I found the problem it's all good. Thanks for the reply and awesome job on the packaging.
    F:L/R LSi 15
    Cen: LSiC
    Sur: LSi FX
    SurBack: LSi 9's
    Sub: Modded PSW1000
    Sony STR-DA4400ES
  • chris23120
    edited May 2013
    Awesome job finding the problem. I used to have a bad intermittent hum problem. A few years back when I was doing some upgrades I ran a dedicated line from the breaker box that only the monster box plugs into and then my entire system plugs in the monster. It's cool to look at, and it gives various readouts so you can tell when your systems doing work. I had a local guy buy two of these subs from me. I delivered them and helped set up the system. It sounded quite good but then later that evening he called me with a hum problem. When it got dark and he turned on the lights in his room the hum showed up. The lights never effected mine, but if I plugged in a cell phone in the kitchen to charge it would show up. But you have to expect some issues when you're running 5000 W RMS, and your neighbors just listening to 25 W speakers on their flat screen. Enjoy your system, based on the hardware that you have I'm sure it's going to be quite impressive.
    Onkyo TX-NR3007
    Polk Audio RT5000
    -RT3000 front
    -CS1000 center
    -FX1000 dipole
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited May 2013
    It's amazing how many time it's the cable tv ground problem that causes these problems, glad you found it nme medic!
  • custopper30
    custopper30 Posts: 252
    edited May 2013
    Good job finding the problem. I know they can be a tricky one sometimes
    Receiver: Denon 1912
    Speakers:
    Fronts: Polk Audio Monitor 70s (x2)
    Rears: Polk Audio Monitor 50 (x2)
    Center: Polk Audio Monitor 70
    KLH Sub GFX-550
