Ground Loop Help
jeremymarcinko
jeremymarcinko Posts: 3,785
I need some advice, I recently replaced an aging 2ch yamaha power amp w/ a 2 prong A/C cord with a new amp that has a 3 prong. Now I am getting some ground loop buzzing from the main speakers when I turn on my plasma tv which has the only other 3 prong in the system. I have a tried the cheater plug and it works but is it ok to use? I dont want to damage anything of course. Or would a power conditioner solve this? I looked at the Panamax 4300 that was suggested on another thread but would like a quick yay or nay before I purchase.
Post edited by jeremymarcinko on
  • Habanero Monk
    Habanero Monk Posts: 715
    edited May 2013
    All equipment plugged into the same outlet?
  • jeremymarcinko
    edited May 2013
    yea I tried plugging the amp in on the next outlet down on the wall but still buzzed. I pretty sure everything on that wall is on the same circuit.
  • Habanero Monk
    edited May 2013
    Ground is referenced at the outlet so hum could still exist on same circuit but multiple outlets. Can you plug everything into the same outlet for testing purposes?
  • jeremymarcinko
    edited May 2013
    Tried it made no difference.
  • Habanero Monk
    edited May 2013
    Generally having everything in the same outlet will fix ground loop. Is there a Cable Box plugged in? Other than that you will have to use a cheater plug.
    If you get the Panamax make sure you can return it if it doesn't work.
  • jeremymarcinko
    edited May 2013
    No cable, only a ps3 and my antennea cable into the tv, made no difference disconnected. The buzz is only present with the both the tv and avr on at the same time. avr&amp no buzz, tv&amp no buzz, tv+avr+amp=buzz. It seems the ground loop is created thru the hdmi cable and interconnects as the tv and amp are not seeing each other until the avr is powererd up. My thinking is the cheater plug will be ok to use since the amp will stay grounded thru the tv but if I turn the tv off for music listening the amp would be ungrounded. I may give the panamax a try.
  • zane77
    zane77 Posts: 1,696
    edited May 2013
    Did you try running a separate ground wire tied to the chassis of all three pieces? Sometimes that will get rid of a ground loop.
    Two Channel
  • jeremymarcinko
    edited May 2013
    No, but I like that Idea. I will give it a try
  • jeremymarcinko
    edited May 2013
    Ha, Thanks Zane, it worked. No more buzz.
    You too Habanero I really appreciate the help
  • zane77
    zane77 Posts: 1,696
    edited May 2013
    Glad that took care of your problem and happy I could help someone out after all the help I have found on this forum
    Two Channel
  • zingo
    zingo Posts: 11,258
    edited May 2013
    Very good suggestion, and congrats on losing the buzz!
  • jeremymarcinko
    edited May 2013
    I think I will still get the panamax though. Upon further investigation I am still getting a very slight buzz from all 5 channels but can only be heard with my ear as close as 4-5 inches from the tweeters any more and I cant hear it. Not a hiss but a buzz that is there if the avr is on, no matter if the tv or is on or even connected. Zanes suggestion definitely worked the previous buzz could be heard 9 ft away in a silent room and was consistent with the TV. The brighter the screen the louder the hum. The noise I am hearing now could of always been there even with the old amp and I never noticed it.
    edited May 2013
    zane77 wrote: »
    That was the old school way, we used to do that especially on TT's, RTR's.
    A 2 buck cheater plug will work for most applications. Also some cables are more prone to ground loops than others, IC'S specifically. As far as safety on a cheater plug, have one in my system on my amp now for about 5 years now with no issues. Grounding will still happen between pieces by cables to some degree.
  • Speedskater
    Speedskater Posts: 495
    edited May 2013
    I won't quote 'ZITFUL's' post, but electricity in the real world just doesn't work that way.
    Three excellent papers on how electricity really works.
    Power and Grounding For Audio and Audio/Video Systems -- A White Paper for the Real World
    http://www.audiosystemsgroup.com/SurgeXPowerGround.pdf
    UNDERSTANDING, FINDING, & ELIMINATING GROUND LOOPS IN AUDIO & VIDEO SYSTEMS
    http://www.jensen-transformers.com/an/generic%20seminar.pdf
    Power Distribution and Grounding of Audio, Video and Telecommunications Equipment White Paper (986 KB)
    http://www.middleatlantic.com/power.htm
  • zane77
    zane77 Posts: 1,696
    edited May 2013
    Tony, what can I say I'm getting old! You sound like my wife, LOL!
    Two Channel
  • zane77
    zane77 Posts: 1,696
    edited May 2013
    That is also how we eliminate grounding problems in current generation CT and MRI scanners and for patient safety by not having chassis floating above ground potential
    Two Channel
  • PolkieMan
    PolkieMan Posts: 2,446
    edited May 2013
    Very nice papers on how electricity really works. Thanks!
  • zane77
    zane77 Posts: 1,696
    edited May 2013
    Great references Speedskater
    Two Channel
  • Habanero Monk
    edited May 2013
    That could be gain induced hiss from the amp. unplug the inputs from the amp and see if the noise goes away. Then if you have multiple sources connect one at a time and see if one, more than one, or all give you hiss. Is this hiss coming out of the tweeter?
  • jeremymarcinko
    edited June 2013
    Yea, there is a slight hiss very faint from the tweeters, but the buzz has now been eliminated. Zanes suggestion worked almost completely the first time around. But I went back and rewired the chassis grounds with heavier 12ga wire and terminated ends and connected to the ground at the outlet, which completely eliminated any audible ground noise. The first time I just used some thin 18ga wire for testing purposes and it left some faint buzz in the tweeters. Now the hiss I am not to concerned about I can only hear it with my left ear an inch away from the tweeters and its dead quiet if I put my right ear up to the tweeters. So I can imagine in a couple of years this hiss will go away on its own.:rolleyes: I did order the panamax as well but haven't received yet, crutchfield has the 4300 on sale for only $199 so figured it can't hurt and I like the thought of seeing the incoming voltage right there on the lcd.
  • daboyz
    daboyz Posts: 5,207
    edited June 2013
    Good decision on the Panamax. The single best way.
