For Sony ES fans: 5000ES for $981.09
Mike682
Mike682 Posts: 2,074
edited June 2004 in Electronics
Just was poking around the internet and found the 5000ES for 981.09 at ecost:
http://www.ecost.com/ecost/ecsplash/shop/detail.asp?dpno=394498
not sure if in stock says to "please call" but it's worth a shot to save around $600.....(retails for $1499.00)
Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
Post edited by Mike682 on
    F1nut Posts: 51,713
    edited June 2004
    Sony has been recalling all their digital drive receivers. I wouldn't touch it with a ten foot pole.
  • Mike682
    edited June 2004
    I guess that explains the price drop on that site....
    Thanks for the heads up.
    Mike
    Mains: polk R30
    Center: polk CSi3
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2004
    It is not a total recall, just a recall on those that have experienced specific problems. The problems essentially cover the 1000ES - 3000ES. Far fewer problems have been reported concerning the higher end, 5000ES - 9000ES, models.
    I wouldn't recommend them at this point either, as mentioned previously by F1Nut.
    There are a couple very satisfied new Digital ES owners on this board, so these statements are simply for information purposes.
  • ChaoticMage-XBA
    ChaoticMage-XBA Posts: 11
    edited June 2004
    What exactly are the problems :confused:
    I recently purchased a 2000 ES and have only hooked it up for a few minutes since i recently moved... I haven't had time to really sit there and mess with it... Although while i did test it, it sounded great and seemed to work fine...
  • dorokusai
    edited June 2004
    A "hissing" sound has been the most common problem. The sound is often heard at normal to loud listening levels and is very audible.
    It's a consumer action recall, meaning that it's not every unit that has issues, it's a case by case issue. It also means that it's on the consumer to have it resolved thru the Sony dealer chain, or service center.
  • ChaoticMage-XBA
    edited June 2004
    Great, thanks for the reply...
