Spikes for my Polk Subs
Devlon
I broke off one of the rubber feet on one my Micropros somehow and I decided to try spikes. Problem was that all the spikes I researched needed for you to do some drilling of larger holes in your sub for the socket part of the spike to fit Too much of a hassle. I called Polk and they said the threads on their sub feet was 3/8". I saw these on Parts Express, ordered them, and they work perfectly in the sockets already in the sub. At first, I though they didn't look cool enough but after I installed them on my subs you can't see them anyway. They work perfect! Just thought I pass this on. I assume they'll work with any sub posts or spikes that are 3/8"
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-725
Living Room: HK AVR 354 as pre/pro, 2 x Polk Audio Micropro 4000, Adcom GFA-7500, 2 x Mirage OMD-15
2 x Mirage OMD-5, 1 x Mirage OMD-C1, APC H15, Sony S790, Philips 52" LCD, Beogram 3000, FAT (Firestone Audio Tobby DAC), Harmony One
Den: Sherwood R-972,as pre/pro, 2 x Velodyne SPL-1000R, 3 x Crown Drivecore XLS1500, 2 x Polk Audio Lsi9
1 x Polk Audio Lsic, 2 x Polk Audio Lsifx, Sony S790, APC H15, Dspeaker Dual Core 2.0, W4S DAC 2, Keces DA-151
Post edited by Devlon on
Thanks for sharing.Speakers: SDA-1C (most all the goodies)
Have the spikes changed the sound/performance of your sub?Front Speakers: Polk Audio LSi15 x 2
Center Speaker: Polk Audio LSiC
Rear Speakers: Polk Audio LSiF/X x 2
Subwoofers: Polk Audio PSW505 x 2
AVR: Denon AVR-3313CI
Amp: Emotiva XPA-5 -
The DSW Pro subs use 6mm threads.Political Correctness'.........defined
President of Club Polk -
ecauseHave the spikes changed the sound/performance of your sub?
It's hard to say, because I got the Sherwood R-972 (Trinnov mode) almost the same day the spikes came in, and when I ran Trinnov the subs changed so dramatically that I don't know how much could be attributed to the spikes. I do know that the subs don't move anymore like they would sometimes do on movies like U-571.Living Room: HK AVR 354 as pre/pro, 2 x Polk Audio Micropro 4000, Adcom GFA-7500, 2 x Mirage OMD-15
1 x Polk Audio Lsic, 2 x Polk Audio Lsifx, Sony S790, APC H15, Dspeaker Dual Core 2.0, W4S DAC 2, Keces DA-151 -
Gotcha. Glad to hear you are enjoying your system more!Front Speakers: Polk Audio LSi15 x 2
Never thought about spiking a sub, interestingMains: Polk Audio SDA-2Bs
Center and Surrounds: Bic Acoustech
AVR: Pioneer 1015tx
Amp: Anthem Amp 1
Turntable: Project Debut III
Inputs: Xbox 360, Samsung BDP-1000, Apple TV -
Spike your subs! I put spikes on my 505's and couldn't believe the difference.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
How did the difference change??Receiver: Denon 1912
Speakers:
Fronts: Polk Audio Monitor 70s (x2)
Rears: Polk Audio Monitor 50 (x2)
Center: Polk Audio Monitor 70
KLH Sub GFX-550
